Electronics Internal amp and speakers?
Discussion in 'Modding' started by Duke Raoul, 18 Aug 2007.
  1. Duke Raoul
    Duke Raoul New Member
    19 Apr 2007
    Hi there,
    I'm planing to build a small footprint custom case.
    Now I was wondering if anyone knows a way to enable it to play sounds without any external amp/speakers.
    Can i use some notebook speakers? Do they have an internal amp?
    Or can I maybe just "pimp" the standard system speaker?
    The sound doesn't have to be surround. If necessary not even stereo.
    I basically just want my computer to be able to "speak"...
    So the priority no 1 is small size and not the technic :eyebrow: ;)
    Greetz
    Duke Raoul
  2. GuitarBizarre
    GuitarBizarre <b>banned</b>
    2 Jul 2007
    Dissasemble the headphone port of the standard audio and split it so you can route two ghetto soldered wires to the inside of the case somewhere? If you can do it without demolishing the module it should still allow normal use, although it may be prudent to implement a switch to control that.
  3. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
  4. Duke Raoul
    19 Apr 2007
    Thanx for the quick replies!
    @ GuitarBizzare:Thanx for the Idea. I could probably manage to get the headphone port inside the case.
    Although this would still mean I would have to get some sort of amp+speakers inside, too, doesn't it?
    @Scirocco: Thanx for the links! Only problem I have: I won't have any 5.25" bays in my rig...
    I guess it can be modded (read: "stripped") without too much trouble?!? Would it make a big difference in size?
    Do you or anyone else maybe have some pictures of the inside of one of those systems?
    Greetz
    Duke Raoul
  5. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    You can get all sorts of small amplifiers that would work in this situation (Link)
    These kits are not that hard to assemble if you can solder. If you really dont care about having stereo then the 7W mono amp is small and cheap, if you do then you can get two, one for each channel.
    Even better, this looks like a plug-n-play solution Link
    Moriquendi
  6. Duke Raoul
    19 Apr 2007
    All right!!
    That looks like the thing I need for this job!
    I just hope these are not out of date, since they are made in "west-germany" ;)
    Thanx a bunch!
  7. Moriquendi
    3 Nov 2005
    I wouldn't worry about it, Maplin are awful at keeping their site up to date. Seeing as you're in Germany you might easily be able to find them cheaper or atleast closer, when I was looking at them a couple of months ago most of the sites I found were on the continent.
    Did a bit more looking, you'll probably find this link more useful, they're the people who make them (Kemo-Electronic) and they seem to have a shop (my German is non existent but "BUY NOW" is fairly self explanatory)
    Moriquendi
  8. Duke Raoul
    19 Apr 2007
    What a service!
    I love this forum!!!:thumb:
    Edit: just for anyone who might want to use that link:
    Sadly they're only selling to business customers, not to private persons...
  9. Moriquendi
    3 Nov 2005
    Ah well, I guess youll have to get your keyboard out and do some googleing yourself, I cant do it all for you :rolleyes::p.
    Best of luck, let us know how you get on.
    Moriquendi
  10. lost_modder
    lost_modder New Member
    5 Dec 2006
    The older e-machines came with a speaker set that was only two speakers on a headphone wire. You will be fine with no amp or anything. And it will be stereo.
  11. TrainedNoob
    TrainedNoob Needs more zipties.
    27 Aug 2007
    I am not sure what the above manufacturers are using, but shielded neodymium driven speakers would probably be best to prevent interference with say hard drives with data on them.
  12. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    one option you have if you have access to a junk yard of some sort is to locate an oldstock sound amplifier. Toucan normally find these in old ford vehicles because often the amplifier was a separate unit from the headunit itself. That are all 12 volt and draw litle current because they were not all that powerful. You can see an example of one in my signature.
    Really just depends on how much you want to solder, personally if it requires no soldering its hrdly worth building or modding.
