Electronics internal oscillator pic 16F88
Discussion in 'Modding' started by micpic, 1 Aug 2007.
  1. micpic
    micpic What's a Dremel?
    1 Aug 2007
    Hi,
    I'm a newbies on pic microcontroller, I want to use pic 16F88 with his internal oscillator but I don't know what are registers may I configure! thanks! :duh:
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Welcome to Bit forums. :thumb:
    Moving this to Electronics section of Modding. Confusing system we have. :confused:
    Check the Useful Links on PICs, may get you going.
  3. const_
    const_ What's a Dremel?
    15 Nov 2005
    hi
    what programming language you use ? one way is to check the header file for that PIC you got
    in assembly its .INC file and in C it is .h file all the config fuses should be somewhere in these files
    there are a lot of other stuff on these files.
    what you want is this "INTRC_IO" which activate the internal oscillator and give you IO on the pins which a normal crystal oscillator would be.
    i use CCS i would just write
    #FUSES INTRC_IO
    hope that helps
  4. HYTEC
    HYTEC What's a Dremel?
    1 Jul 2007
  5. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    You want to be setting bits in the config word to use the internal oscillator. These bits cannot be set in realtime so you must use the __CONFIG directive to assign them. See "Special Features of the CPU" section in the datasheet.
  6. micpic
    1 Aug 2007
    Thanks for your answers,
    I use Picc compiler, in datasheet of pic16F88, I see OSCCON register, and for example if I want to use 8Mhz, I must configure this to OSCCON = 0b01110000, so my question is beyond this register, does exist other register to be configured? I don't need clock signal output.
    Thanks!:duh:
  7. const_
    15 Nov 2005
    in C setting up the oscillator and many other MCU peripherals dosent require setting values to registers. there are function that does the work for you.
    i haven't used PICC before is it Microchip C that setup on MPLab or is it HI-tech C?
    regardless you should check the examples that come with the package to get an idea how its done.
    and as i said in CCS or PCW as it sometimes called, i setup the internal clock with no clock out this way:
    #FUSES INTRC_IO
    and i set the frequency using the delay directive
    #DELAY(8000000)
    hope that helps.
  8. SteveyG
    23 Nov 2002
  9. micpic
    1 Aug 2007
    Thanks for your answers guys!
    Ok, if i understand, I must do _config .INTRC_IO as R6 & ... in the head of my file .c
    So, i find schematic of pic programmer, easy to do and cheap, connected in parallel port? my computer hasn't serial port (jdm programmer).
    Thanks! :)
  10. SteveyG
    23 Nov 2002
    If you're using a C compiler, how you set the config fuses is defined in the documentation. For C18 it's likely to be "#pragma config _INTRC_IO"
  11. micpic
    1 Aug 2007
    Thanks for ours advices guy! so, to configure pic microcontroller in C compiler (hi-tech) using internal oscillator, i must do:
    __CONFIG (INTIO & WDTDIS & BORDIS & UNPROTECT & LVPDIS & MCLRDIS & ....);
    and in main code: I must specify OSCCON register!
    Thanks! :thumb:
  12. SteveyG
    23 Nov 2002
    Sounds about right, though I'd want BOR enabled, (and MCLR if you're using a debugger).
  13. micpic
    1 Aug 2007
    Ok!
    about BOR could you give me some explanation? :blah:
  14. SteveyG
    23 Nov 2002
    The brown out reset is designed to hold the PIC in reset while the supply voltage is out of spec. It's designed to prevent erratic operation that would occur if the supply voltage is too low.
    If you look at the electrical characteristics section of the datasheet, you'll see that the device can only run at certain frequencies at certain supply voltages. You would then set the BOR parameters to ensure the device doesn't try to run when the voltage is too low.
  15. micpic
    1 Aug 2007
    Thanks!
    your advice is very important, in the future, I turn BOR enabled to prevent noise and to fix problem if supply is under the threshold.
    I have one question about my pic, it marks 16F88-I/P, you know what means the last I/P? :blah:
    So, for my pic programmer(serial port), I want to use this schema but I don't know if it works:
    Tx ---[4k7]----------MCLR/Vpp
    RTS---[4k7]----------RB7
    DTR---[4k7]----------RB6
    CTS------------------RB6
    GND------------------Vss
    +12v----[7805]-------Vdd
    :rolleyes:
    An another schematic is:
    http://www.hiboox.com/lang-fr/image.php?img=0uhd40as.jpg
  16. SteveyG
    23 Nov 2002
    I/P means that it's of industrial specification (-40 to 85C) in a PDIP package (skinny dual in line).
    I'd avoid that programming schematic, it may work, but it certainly isn't adhering to the electrical specifications of the PIC - the serial port swings -12 to +12V. Those 4k7 resistors will limit current through the protection diodes to less than 1mA, but it isn't optimal ;)
    My advice, especially if it's the first device you're programming is to shell out the cash for a programmer you know is going to work. The Microchip PICkit2 is affordable and flexible for most users and should eliminate some uncertainty when trying to get your first PIC to work.
    If you really don't want to spend the £20 or so, take a look on ebay for PICkit2 or ICD2 clones. You may find some for less than a tenner. If that's too much, but you still have a standard serial port on your PC (not a usb to serial converter) then try building the JDM programmer.
  17. micpic
    1 Aug 2007
    Ok! thanks guy!
    I will try to find PICkit2 or ICD2 clone in ebay website, if it isn't expensive! so tomorrow, i will try the diagram of top, I keep you informed results.
    Thanks again ! :)
