Networks Internet and connecting through proxy's??
Discussion in 'Tech Support' started by davie107, 30 Sep 2009.
  1. davie107
    davie107 Linux or Windows???
    18 Dec 2007
    Hi all, at school we can connect to the internet in the sixth form common room via the use of a proxy. To do this we were told to enter it into internet explorers lan settings under the proxy address and through port 80.
    My first question is, is it possible to do the same fore firefox as when i tried entering the proxy address it didnt connect to the internet?
    My second problem is that when i get my laptop home i have to remove the proxy settings to connect to the internet is it possible to set it up so that when it connects to the school wireless it automatically connects via a proxy, and when through my home network it connects normally.
    Thirdly after being connected to the school wireless for roughly 15 mins the connection times out and i have to reconnect again which is a pain as i have to reset my laptop as simply repairing the connection or disabling and enabling doesnt work. Is there a way round both of these problems?
    Thanks any feedback on the problems is very much appreciated.
    By the way im running xp pro on an ibm x31, if that helps
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    in device manager.. double click on your wireless network card and disable power saving, this will fix the card from going to sleep and never coming back on until reboot- this even happens on newer laptops, lame
    makes me wonder sometimes on the software end of things on these pre-builts.. on netbooks they'll even load it up antivirus and a bunch of crapware and wonder why people aren't happy with the speeds + the netcard goes out :sigh:
    here's profiles you can make (with shortcuts) for the different proxies setup in firefox
    http://www.lytebyte.com/2007/05/10/creating-and-handling-different-profiles-in-firefox/
    proxies are setup in avanced > network > connection > settings
  3. davie107
    18 Dec 2007
    right thanks for the help, i managed to sort out the power managment, thanks aswell for the profile setup guide,
    the only problem i am having with firefox is setting up the proxy as in internet explorer i just added the proxy address and port 80, when i do this in firefox it doesnt work any ideas?
    Im also curious about the conection timing out every 15 mins or so and if there is anything i can do to stop this??
  4. dushuai
    dushuai What's a Dremel?
    9 Sep 2009
    In firefox , advance option -> secury option-> set,you can use the same proxy setting in it.
    about 15 mins go dead and must reconnect wifi,I think it is caused by OEM softwares ,you should use windows wifi manager to connect wifi,try again.
