News Internet Explorer 10 bug blamed on hybrid graphics
Discussion in 'Article Discussion' started by Gareth Halfacree, 4 Mar 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. PingCrosby
    PingCrosby What's a Dremel?
    16 Jan 2010
    I usually find spraying my Internet Explorer first with 'Buggo Blastaway' ( from Ronco, they make great xmas prezzies ) usually cures it
  3. jrs77
    jrs77 Modder
    17 Feb 2006
    Just laughable...
    The other browsers have no problems on systems with hybrid-graphics, so the question is not about the systems, but about the software. Microsoft simply didn't check for compatibility and now blames the others.
    If I were working at Microsoft I would be hiding under a rock.
  4. Amsalpedalb
    Amsalpedalb What's a Dremel?
    24 Nov 2010
    I love how they made IE an OS exclusive. Do they think someone is going to upgrade to Win8 because it has IE10? Especially when Chrome, Firefox etc have no such OS limitations on updates.
  5. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    Just laughable...
    Nvidia and AMD manage to update their drivers for game releases but not everyday application releases?
  6. Deders
    Deders Modder
    14 Nov 2010
    Don't modern graphics cards clock themselves down to save power nowadays anyway? My 560TI runs at 50MHz when it's only running the desktop, having optimus or similar technology seems redundant.
  7. SexyHyde
    SexyHyde Minimodder
    24 Jul 2009
    @Deders its about power not speed. The intergrated graphics will use a lot less power than any dedicated graphics. And when using a battery every drop of power counts.
  8. Griffter
    Griffter What's a Dremel?
    1 Jun 2012
    todays gpu's are finding it more and more difficult to be compatible with **** anyway.
  9. itrush07
    itrush07 Minimodder
    28 Nov 2007
    Haha, very catchy title.. "it doesn't work properly if you're using hybrid graphics." :(
  10. Pinguu
    Pinguu Noot Noot!
    8 Jul 2012
    Wait, people still use Internet Explorer? You learn something new every day :D
  11. faugusztin
    11 Aug 2008
    "Nothing appears to issue, while similar systems install the software without issue."
    /me can't understand this one :D. Maybe few missing words ?
  12. Gareth Halfacree
    4 Dec 2007
    I accidentally two. Fixed, ta!
