Windows internet explorer problem
Discussion in 'Software' started by jinksy, 23 Jun 2006.
  1. jinksy
    jinksy What's a Dremel?
    21 Jun 2006
    My problem is that when i am using internet explorer it is taking couple of minutes to load up address's when address is placed in address bar though if i click on one of my faviourites it goes straight to it no problem i have the currnt spy doctor and currnt norton sucurity and they don't detect anything . i have down loaded firefox and i tried to delete explorer so i can re downloaded it from microsoft but everytime i try it tells me that some other programme is using it.
    I would be much appreciated if anyone has any suggestions .
    regards Jinksy
  2. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    Explorer is integrated into windows - it can't be removed so don't worry about keeping it around. I'll (try to) refrain from making any fanboy statements by saying that you're making a good decision by downloading Firefox. Give that a go and see if that speeds things up for you. There are also tweaks out there for FF that can make pages load quicker too (eg. Fasterfox)
    What version of IE are you running? Are all the updates/patches installed?
  3. Arthur2Sheds
    Arthur2Sheds Jackson
    19 May 2003
    If another program is using IE when you attempt to uninstall, you probably have spyware, a trojan or some other sort of nastiness. Try running your scans again in Safe Mode.
    IE can be removed through Add/Remove Windows Components. This isn't really necessary. Just stop using it.
    And yes, you made the right choice with Firefox.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    All that does is remove IE shortcuts and file associations, making it more difficult to open IE.
    How to reinstall or repair IE in XP
  5. jinksy
    21 Jun 2006
    yes all up to date thank you for your reply
  6. jinksy
    21 Jun 2006
    Thank you for your reply
    regards Jinksy
