Networks internet troubles
Discussion in 'Hardware' started by kaneso, 30 May 2004.
  1. kaneso
    kaneso What's a Dremel?
    30 May 2004
    well i recently got a new modem cus my old 1 just wouldnt work anymore its a zoom adsl usb model 5510
    i can get online browse the web ect but i cant play anygames online go on any messaging programs or really anything else that acceses the internet
    i really need help cus im a msnm addict :D
  2. a9on87
    a9on87 ...
    2 Nov 2003
    Do you have a firewall (could be windows built in firewall) that could be blocking certain ports? If so it is probably only allowing port 80 which is used for web browsing etc.
    Is the modem just a modem or does it have a built in router - there may be some settings to change the allowed ports if it is a router.
    A bit more information about the problem (ie windows version, firewall info) is needed to give more advice.
    Hope this helps and welcome to the forums!
  3. [cibyr]
    [cibyr] Sometimes posts here
    30 Nov 2003
    USB modem = software = prolly what's stuffing you up. Check if there's any configuration shiz. And next time buy an ethernet modem/router :p
  4. kaneso
    30 May 2004
    i hav all firewalls turned off including windows xp 1
    i use windows xp pro with serive pack 1 it does hav software with configuration but i hav no idea wat to edit im used to simple modems where u install software plug in modem and ur online :sigh:
  5. kaneso
    30 May 2004
    in advanced settings i get these options to change
    wan settings
    lan settings
    dns
    adsl config
    misc config
    which 1 u reakon will hav settings i need to change?
  6. [cibyr]
    30 Nov 2003
    I'd say either wan (most likely) or lan. If you post screenshots of all the prime suspects I'm sure we could figure it out - don't worry about image quality so long as the text is readable.
  7. kaneso
    30 May 2004
  8. Haddy
    Haddy World Domination
    22 Jan 2002
    nothing in there....try screeners of the other selections...
  9. kaneso
    30 May 2004
  10. Haddy
    22 Jan 2002
    I take it those are under the basic setup? If so whats in the advanced setup?
  11. kaneso
    30 May 2004
    this is advanced setup
  12. buzzy
    buzzy What's a Dremel?
    27 Dec 2003
    1. Try setting "DHCP client" to enabled so you can get an IP from AOL.
    2. FFS please restrict HTTP server access to "LAN" so that people on the internet can't connect to your router's config pages!
    Buzzy
  13. kaneso
    30 May 2004
    ok i changed to lan thx for that and also wat should i put as host in dhcp?
    cus it keeps revertig back to diabled unless i hav the host
  14. Shadow_101
    Shadow_101 Mudkips.
    12 Feb 2004
    i had a quick google of your modem, i found this on the zoom website, dunno if its any use to you but it seems like the right thing.
    PPP Half Bridge
    If your ADSL service provider uses PPPoE or PPPoA encapsulation, you can enable PPP Half Bridge, which mode bypasses the NAT protocol. When you enable this mode, it passes the WAN IP address (issued by the ADSL service provider) though the ADSL modem to the remote user's computer. This will allow games and applications like NetMeeting and MSN Messenger to authenticate an IP address.
    To enable PPP Half Bridge, follow these steps:
    1. Open the Zoom Web Console (http://10.0.0.2), click Advanced Setup, and click the Misc Configuration button.
    2. If you are using PPPoA encapsulation, from the PPP Half Bridge drop-down menu, select Enable.
    3. Click the Save Changes button and then the Write Settings to Flash and Reboot button.
    4. Now you must change encapsulation setting from the default the PPPoE LLCSNAP to PPPoA VCMUX. To do this, click Basic Setup. Then from the Encapsulation drop-down menu, select PPPoA VCMUX.
    5. Click the Save Changes button and then the Write Settings to Flash and Reboot button.
    6. Verify that your TCP/IP properties are set for DHCP. You may need to release and renew the IP address.
    hope this is of use :rock:
  15. kaneso
    30 May 2004
    ty for the help jsut 1 more question how do i release and renew my ip?
  16. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    on the modem i dont know, but in windoze go to comman prompt and type:
    Code:
    ipconfig/release
    or
    Code:
    ipconfig/renew
  17. Shadow_101
    Shadow_101 Mudkips.
    12 Feb 2004
    the simplest way is to jst reset or turn off then back on your modem.
