Scratch Build – In Progress INVERTED by ToB1
Discussion in 'Project Logs' started by ToB1, 19 May 2010.
What color should I have on the plexi I'm going to use for the feet?
  1. Clear
    8 vote(s)
    15.1%
  2. Smoked gay/black
    23 vote(s)
    43.4%
  3. Red
    21 vote(s)
    39.6%
  4. Other (Specify!)
    1 vote(s)
    1.9%
  1. ToB1
    ToB1 What's a Dremel?
    18 May 2010
    Almost finished with the feet! :)
    Hole for the fans on the top of the case...
    Last to holes for the locks:
    What do you think about the feet?
  2. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
    Hey Tob1, feet looking good. Sorry I've been a bit quiet of late, even on my own forums (not claiming ownership of bit-tech here, Tob1 posts on our forums too).
    Are you going to paint them or leave them au natural?
  3. ToB1
    18 May 2010
    The plan is to paint them black to make them go with the red and black theme :)
  4. wolfy
    wolfy What's a Dremel?
    18 Oct 2010
    The feet look, awesome, i cant wait to see it all finished
  5. ToB1
    18 May 2010
    I'm glad you like them! :)
  6. ToB1
    18 May 2010
    I've cut the motherboard tray, and made a piece of MDF to cover the gap between the motherboard tray ant the vertical separator.
  7. ToB1
    18 May 2010
    Some of the work that still remains, and some more pictures of the case...
    Here are the spacers I've cut to hold the HDDs in place, and the new SATA-cables that will be used to make this a homemade hot-swap.
    Hope you like what you see! :)
  8. ToB1
    18 May 2010
    After waiting half a year to purchase the right fans from a Norwegian store, I've finally got 6 new Scythe Gentle Typhoon 1850RPM! :)
    I'll try to get most of the work that's left on this built, done during a few weeks, but all the painting will have to wait until the temperature rises. I don't think spray-paint and -20°C is the best combination :p
    My desktop at the moment :p
  9. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Smoked gay sounds good.
  10. KidMod-Southpaw
    28 Sep 2010
    I prefer my gays flamegrilled.
  11. wbdog206
    wbdog206 not me
    15 Jan 2007
    Very nice. Can't wait to see more.
  12. ToB1
    18 May 2010
    Thanks! :)
  13. ToB1
    18 May 2010
    I've got a lot of things done lately, and I hop you are ready for a new update!
    This update includes the mounting of the feet, hole for the fan controller, testing of the front panel, and cable holes.
    First some soldering to do...
    Then I had to lower the screws.
    Finally ready to be mounted!
    I've also milled and drilled hole for the fan controller in the outer front panel.
    The result!
    Holes for the cables, and testing of the hot-swap function...
    The holes for the hot-swap connector looks pretty ugly on the photos, but they actually look quite good in real life.
    Now, what do you think?
  14. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    It's getting really cool your case! :rock:
    Congratulations! :thumb:
  15. ToB1
    18 May 2010
    Thanks! :)
  16. Javerh
    5 Sep 2006
    I'm loving the grooves for the cables. Was planning on doing something similar for my next thing.
  17. ToB1
    18 May 2010
  18. Marcos_Viegas
    6 May 2010
    Wow man, the attention for details make this case awesome! :jawdrop:
    Congratulations! :thumb: :rock:
  19. Dahl1n
    Dahl1n What's a Dremel?
    16 Jan 2010
    rep ++ love the built and its awesome :D will have my eyes on your projekt ;) hehe
  20. ToB1
    18 May 2010
    Thank you! :)
    Thanks! I am glad you liked it!
