Scratch Build – In Progress INVERTED by ToB1
Discussion in 'Project Logs' started by ToB1, 19 May 2010.
What color should I have on the plexi I'm going to use for the feet?
  1. Clear
    8 vote(s)
    15.1%
  2. Smoked gay/black
    23 vote(s)
    43.4%
  3. Red
    21 vote(s)
    39.6%
  4. Other (Specify!)
    1 vote(s)
    1.9%
  1. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Looks stunning man!
  2. MarcosLFV
    MarcosLFV What's a Dremel?
    7 Mar 2011
    Wow... I'm spechless... :jawdrop:
  3. ToB1
    ToB1 What's a Dremel?
    18 May 2010
    Thanks for the comments! :)
  4. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    great case, love it! i have a suggestion for the "power to the switch" issue, why dont you simply solder cables from the psu cable to the trafo for the switch? then as soon as you connect your powercable to the "hole in the wall" you will also have your switch up and running, and because the switch is in the case, open up both switch and psu and solder the cables on the inside. i think that would be a good solution. =)
    then you can ofcourse hide the switch psu, maybe behind mb-tray? (should not need very much space without it's shell)
    can write in swedish if it helps =P
  5. ToB1
    18 May 2010
    Thanks!
    I have thought about it, but I got Enermax Revolution 85+ 1250W, which is not a cheap PSU, and I don't want to experiment to much with it :p
    If I am going to make it possible to power the switch by the computers PSU, I guess I will use a switch (like in latching button, not network switch) to switch between external power and internal power, if you know what I mean. But for now I will just use the normal power cord and trafo to power the network switch.
    Thanks for the help anyway! :)
  6. Christian_10
    Christian_10 What's a Dremel?
    9 Mar 2011
    very nice !
  7. ToB1
    18 May 2010
    Thank you! :)
  8. ToB1
    18 May 2010
  9. randomhero
    randomhero Minimodder
    6 Nov 2005
    Høres bra ut! Gleder meg til å se hvordan denne blir når den blir ferdig! ^^
    And to you who aren't norwegian:
    Sounds good! Looking forward to seeing this once it's done^^
  10. ToB1
    18 May 2010
  11. TeenGeek
    TeenGeek Worst touch typing ever.
    11 Feb 2011
    for the acrylic, i think you should try black, with red LED in front, and frosted red in back, with leds...
  12. Tna
    Tna Moda'a'foca modding power!
    18 Jan 2011
    wood case :) great modding there
  13. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    Brilliant, you could make and sell these....buy could im suggesting you do!
  14. ToB1
    18 May 2010
    MiNiMaL_FuSS, a lot of people have told me to do that, but unfortunately, I don't have the time and effort to do that right now.
    I finished the case two days ago, but the upcomming week is full of exams, so the next update will probably have to wait until the week after that. Sorry about the waiting :/
  15. TotalGaos
    TotalGaos Stainless steel.. hmm..
    16 Dec 2007
    Have you decided on the switches yet?
    I see two options: using a double switch (one button - two connectors) or (maybe a cleaner solution) modding the 12V feed to the network hub so it can fit in a standard 4-pin psu connector.. Or am I repeating earlier comments (I have authors posts only turned on..)?
  16. phenoptix
    phenoptix What's a Dremel?
    16 Aug 2006
    Hey Tob1, hope the exams went well! Well done on the MOTM nomination. You should put that in your sig! It's a badge of honour!
  17. ToB1
    18 May 2010
    I ended up using the switch (network) the regular way, using the cord it came with.
    Thanks, the exams went really well! :)
    I believe the end of this build is near... Here are some more pictures:
    Hope you have enjoyed reading this worklog! If you wonder about something, feel free to ask!
    (I will probably upload a video of the case in not too long, but it is pretty much done now)
    Now I have to thank my sponsors for helping me out on this build. Thanks for all the support I have got from you! You have made this a lot easier for me! :thumb:
