Development invision power board, weird problems
Discussion in 'Software' started by hyperactive98, 8 Nov 2005.
  1. hyperactive98
    hyperactive98 What's a Dremel?
    30 Mar 2002
    edit: PROBLEM SOLVED! thanks for the help anyway guys...
  2. simon w
    simon w What's a Dremel?
    3 Nov 2003
    What version of PHP is your web server running? IPB requires PHP 4.3+
  3. hyperactive98
    30 Mar 2002
  4. simon w
    3 Nov 2003
  5. hyperactive98
    30 Mar 2002
    im using php 5.0.4, but mysql is 4.1.11, so that shouldn't be a problem..
  6. simon w
    3 Nov 2003
    Sorry, I saw 5.x in the requirements and assumed it was referring to PHP :blush:
    It sounds as though the script(s) aren't reading POST data correctly. Depending on your programming/scripting experience you could dig around in the code to find and fix the issue. Failing that try another discussion forum as such as phpBB or punBB.
  7. hyperactive98
    30 Mar 2002
    I have trouble believing it's a code issue; IPB is a high-end, commerical message board similar to vB. Thanks for the help, I'll just contact invision support; i was just hoping i could get a quick answer here.
