Case Mod - In Progress INWIN 909 MbK
Discussion in 'Project Logs' started by kier, 26 Dec 2015.
  1. kier
    kier -----------------
    1 Mar 2011
    Hi y'all
    It has been quiet for a while regarding MbK builds, but here is a new one.
    Sponsored by:
    This time it will be the INWIN 909 with beautiful EKWB products.
    Colors will be this time external Silver (the case) black (internal) and also some blue.
    But first a few pictures from the case
    Great case, top quality !!!
    First, some hardware in it. This is not the final hardware, but always nice to fill this beauty:
    First work already done ... a blue plate sawn with the same design from the back in it:
    And also this for the "midplate"
    And made some lines black around the squares with black vinyl:
    Placed the final hardware:
    Corsair dominators DDR4 and the Gigabyte GA-X99-Gaming 5P
    Also with some blue details.
    More soon!!!
  2. Jeffinslaw
    Jeffinslaw What's a Dremel?
    26 Jun 2014
    This should be good :)
    -Jeffinslaw
  3. Icelander
    Icelander Minimodder
    3 Mar 2015
    COOOOOOOOOOOOOOOL
  4. Goatzil_11
    Goatzil_11 What's a Dremel?
    24 Dec 2015
    INWIN do make some great looking cases.
  5. Cheapskate
    13 May 2007
    I like that look.:D
  6. kier
    1 Mar 2011
    Thanks, hope so ;)
    :thumb:
    Yes, they are!
    :rock:
  7. Dayaccus
    Dayaccus What's a Dremel?
    19 Dec 2015
    Looking great so far, much better with the blue motherboard.
  8. kier
    1 Mar 2011
    Sponsored by:
    For this build I will use 2 GTX 980 Strix GPUs
    And got some beautiful EKWB products:
    Like the EK-Supremacy EVO - Nickel
    And 2x radiator: The EK-CoolStream PE 360 (Triple) and the EK-CoolStream PE 240 (Dual)
    Mounted the fans
    And rerouted the cables
    Then I found out I had to mount the PSU a bit different than normal, so picked up my Dremel and made a big hole:
    This wil be better for some ideas I have...more on this later.
    Also changed the mobo tray / back for the cables and stuff.
    Back to the water blocks.... Removed the stock coolers.
    And placed the beautiful EK-FC980 GTX Strix - Acetal+Nickel blocks
    Used the pads and EK-TIM Ectotherm
    Also placed the EK-FC980 GTX Strix Backplate
    For the pumps I will use the strong EK-XTOP Revo D5 PWM - Plexi
    And then my eye catcher of the build came in thanks to Bob and Plano plastics: My custom made reservoir:
    Beautiful piece of work!!! Thanks for the great service and beautiful reservoir.
    Placed everything and did some brainstorming.... just for the show:
    More to come!
  9. kier
    1 Mar 2011
    Sponsored by:
    Another update!!!
    First I made a piece of smoked acrylic to cover de side of the 240 radiator
    What has a nice effect with the white illuminated strip which comes with the case.
    Also made a nice black and blue border for the reservoir
    And mounted the Nvidia SLI bridge that will be modded later on.
    This will be my first build with bending tubes but not full in sight
    So I needed some tools from my favotite shop... Highflow
    To start with:
    The XSPC PETG Easy Bending Tool
    And the PrimoChill Versatile Rigid Tubing Bender
    Not to forget the Acrylic/PETG Deburrer
    And off course EK-HD PETG Tube 10/12mm
    Got everything now to bend some tubes:
    To tap the holes in the reservoir I will use the Highflow Tap Kit G1/4
    Also adjusted the midplate for the fittings etc.
    But first a leak test before the hardware goes in. Already mixed some liquid using:
    Ultra Pure H20
    And a little bit of Dye Blue
    This will give you this color:
    Last but not least... a beautiful t-shirt for me and my son
    Thanks Freddy!!!
  10. Donnii
    Donnii Mods By Donnii
    15 Jul 2015
    Looks great ;)
  11. kier
    1 Mar 2011
    Thanks!
  12. kier
    1 Mar 2011
    Sponsored by:
    Time to fill...
    And in the dark with the LED on
    Before I go any further with this, I have adapted the NVIDIA bridge first to the colors of the build
    So removed the green.
    Unfortunately, I found out that the LED in the bridge only works with ref cards. So I made the LED myself (powered externally). Also blue.
    For the next idea I used a sample which Planon plastics sent me with the reservoir. Adjusted this to the dimensions of the mobo, tubes and midplate:
    And applied a LED strip over the entire length
    And for some more original ideas, I have used the ribbon cables from the power supply through a number of acrylic tubes:
    Which I made black.
    And made a blue stripe on it.
    And made the edge of the "cover" beneath the reservoir also blue.
    I also made LED strips around the radiator behind the cover.
    And made this blue again.
    More to come!!!
  13. amagriva
    amagriva Minimodder
    13 Jun 2009
    In a gorgeous context the gpus are a bit shadowed and form a sort of black hole in the center of the build but I'm sure you've still some aces up the sleeves...
  14. kier
    1 Mar 2011
    Thanks mate, still got some more things to do ;) but not with the GPUs. next is left corner below
  15. kier
    1 Mar 2011
    Sponsored by:
    Just a small update before the final shoot.
    Because I have rotated the PSU, I will have to make another connection for the power cord.
    For this, I've cut a piece of blue acrylic and bend it. Also installed the extension:
    Pasted the inside with white vinyl and a square black vinyl on the outside.
    For SSDs I made a kind of bracket from old materials, blue acrylic and SSD brackets like this, so it looks like the SSDs hover.
    Which you can just slide into the compartment.
    Also adjusted the Sata power
    Placed the cover back and installed some blue LED strips behind.
    Next... final shoot!
  16. kier
    1 Mar 2011
    Final update sponsored by:
    And the final pics from this build:
    Lights on:
    That's it!!!
  17. hairyknacker
    hairyknacker Minimodder
    25 Jan 2012
    Kier
    Simply the best yet :thumb:
    Love it
  18. Gurt11
    Gurt11 What's a Dremel?
    30 Nov 2015
    My God that's beautiful. And I don't even like blue that much :p
  19. kier
    1 Mar 2011
    Thanks guys! :rock:
  20. JaPeMo
    JaPeMo What's a Dremel?
    31 Aug 2013
    OMG!!!!!
    Beautifull!!!! :jawdrop:
