Case Mod - In Progress INWIN IW-Q500 re-style
Discussion in 'Project Logs' started by N4cer, 1 Sep 2009.
  1. N4cer
    N4cer Trust no one
    31 Aug 2009
    Greet all! :clap:
    This is my first log on this forum.
    I from Russia, beside me small difficulties with language
    But I think this will not disturb me is divided with you detail of its work, Hope you help me in this. Hope my translator to me too in this will help! :D
    Commentaries with my sides will not much, more photography.
    Victim: INWIN IW-Q500
    Purpose:
    Maximum reliability.
    Maximum usefulness (without fanaticism).
    The Silence.
    Good cooling.
    Strict but attractive exterior.
    Neatness internal device.
    Regrettably I have no information was on sale this model in USA and Europe, but in Russia from was much little. Yes and they long ago skim with production. The History exactly this copy it is enough long, I not even know where he stood before that how do I his(its) have presented. In my hands he has got more dilapidated and without some details. After not долгово uses I have considered his(its) uncomfortable and has sold. Only in year I have understood that has done this in vain. To my joys me his(its) have reselled without spare words.
    Before sale I several has worked on his(its) appearance, on how much was enough time.
    Initial type:
    to be continue...
  2. N4cer
    N4cer Trust no one
    31 Aug 2009
    Contributing the small change right after that as case has got to me in hands.
  3. N4cer
    N4cer Trust no one
    31 Aug 2009
    update
    The case again at me. :)
  4. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Huge tower awesomeness. Those case were just real... damn solid, really, you can build a house on them :)
  5. N4cer
    N4cer Trust no one
    31 Aug 2009
    Has corrected the forward panel, it is necessary to put the second finishing layer and to grind
    Q500 Near to 3Q Xclio Wind Tunnel :)
    Inside
    Many superfluous apertures... :-(
  6. Validus
    Validus What's a Dremel?
    25 Aug 2009
    So far, the translator seems to be working :)
    That case sure has a lot of space. Going to fun watching you fill it up.
    Side note: Those feet give you enough room to put a toggle switch facing down on the front panel? Or did I misinterpret that pic?
  7. N4cer
    N4cer Trust no one
    31 Aug 2009
    Validus
    On the bottom part of the forward panel there was a button reset and cmos, the height of legs was sufficient, that them to press, in general the button reset was pressed by a foot:-D
    I have refused these buttons. :)
    All wires from buttons will be altered, the main thing will be defined with a braid for them and the optimum long.
    Hardware for filling of it case is not present, but I hope that will be, to begin with I will establish wothercooling, and then accessories.
    I will not assort the basic computer :)
  8. N4cer
    N4cer Trust no one
    31 Aug 2009
    Has decided to turn the case. :rock:
  9. N4cer
    N4cer Trust no one
    31 Aug 2009
  10. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    The size of that thing certainly allows you plenty of room to play with.
    What kind of watercooling to you intend to do? CPU & GPU, or just go the whole hog and do the bridges as well?
    I'll keep an eye on this.
  11. N4cer
    N4cer Trust no one
    31 Aug 2009
    Detachable circles in my city it is a rarity, has decided to make.
    :thumb:
    Installation of case panels.
    After completion, has risen as native! :dremel:
  12. Reverse
    Reverse Reverse/srvR
    25 Sep 2008
    Wow, creative with the cutting discs!
  13. PrometheusCon
    PrometheusCon What's a Dremel?
    11 Oct 2004
    Omg. I had to laugh with the dremel disks. Not as a bad thing though... that's so creative! Awesome job.
  14. N4cer
    N4cer Trust no one
    31 Aug 2009
    Complete set Dremel (Bosh) 426 (5 disks, 32мм) in Russia costs 514.08 rbl. In recalculation for dollars($) are ~16$ in Moscow, delivery to my city ~9$ and that for 5 disks for me stand 25$!
    One big disk (that that on a photo above) costs 0.7-1$! It is possible to make 5 disks which almost differ nothing from firm (a thickness 1.2мм), thus considering Of it that the big circle is calculated on the big loadings, my self-made circles grind off almost in 2 times more slowly and thus cut equally. :thumb:
    Quite good difference 25$ or 1$, isn't that so?:naughty:
  15. N4cer
    N4cer Trust no one
    31 Aug 2009
    Processing of an aperture for cooler (80mm).
    We adjust a substrate to the top panel.
  16. wbdog206
    wbdog206 not me
    15 Jan 2007
    Good work. I like the way you flipped the mobo tray.
    I am going to keep an eye on this one.
    Keep up the good work.
  17. modernization
    modernization From Holland
    18 Nov 2008
    Ah nice! Exactly the same case which I'm modding:dremel:
    Only I added some blowholes and some paint. Modded the sidepanels the most ;)
    Good luck!:thumb:
  18. N4cer
    N4cer Trust no one
    31 Aug 2009
    wbdog206
    modernization
    Thanks for support :)
    blowholes and painting necessarily will! About the beginning I will work all design features, then I will cut off all rivets, I will qualitatively paint and I will collect back :) still ahead! :) In the near future I will make blowholes and I will finish all internal surfaces with plastic to close superfluous technological apertures.
    :thumb:
  19. Edge102030
    Edge102030 Son, i am disappoint.
    21 Aug 2009
    i've got that case! :) [​IMG]
  20. N4cer
    N4cer Trust no one
    31 Aug 2009
    Has decided to close all internal surfaces plastic (pvc), it will close all technological apertures and will improve appearance.
    For this purpose to begin with it is necessary will get rid of all sticking out details.
    Was engaged in the promised cuts for 120mm coolers, the same cut will be on other wall and two cuts in the bottom panel for 120mm coolers a radiator.
    :dremel:
