I hope not strongly you I tyre daily updates. 120mm cooler test, they that are not a pity for scratching or breaking those, for check. In the project it will not be used.
[ZiiP] NaloaC One of features of my job, is uses only вкуьуд and the small manual tools, any milling tanks and laser cutting torches. In the near future I will be defined with an arrangement coolers and I will make suitable cuts then I will disassemble the case and I will send in painting, and at this time I will be engaged in the forward panel.
Update 14/09/09. Excuse for the big break! Without superfluous words, photos will tell better. Will stand from above Black ICE Radiator GT Stealth 240!
Не можешь - не пиши . Filimon вообще чисто фотографии сливает без слов на этот форум. Промт гауно односложные предложения лучше этим -> http://translate.google.ru/#
Great project, i am periodicly checking this page, today i registered for say to thank you. I have case like that I am also modding it, your ideas are very good. Please continue your project
