Scratch Build – In Progress Ioncito v2.0 [Update TODAY]
Discussion in 'Project Logs' started by elGafas, 27 Oct 2009.
  1. elGafas
    elGafas Myopic
    2 Jul 2009
    Yeah I know, PSU and hdd carry both are hanging... both suffered the flight.
  2. elGafas
    elGafas Myopic
    2 Jul 2009
    Thanks for your comments!
    Here's a no-update :p
    Ioncito next to a HAF and a 1.5l coke so you can see it size:
    Sketchup doesn't like me... this is my best try... HDD fitting test:
    A pic with the case fully closed:
    Upcoming hard:
    XSPC Acrylic Reservoir + Swiftech MCP355 + MCR220-QP Rad+ Zotac ION Atom 330 + white tubbing + 3M M110 Pico Projector + 2 HDD in RAID0
  3. Guest-23315
    Guest-23315 Guest
    Thats just sweet :thumb:
  4. elGafas
    elGafas Myopic
    2 Jul 2009
    Thanks!
    I've been really busy @ work, thats why I didn't update this project
    Some "better" sketchs i've done for V2.0:
    The red brick it's the pico projector.
    What do you think about a ZOTAC GeForce® GT 240 AMP!® Edition + ZOTAC ION ITX F "gaming" rig?
  5. Geowal19
    Geowal19 What's a Dremel?
    16 Apr 2009
    Looks cool got any pics of your sofa? Where did you get that mesh? I desparetly need some!
  6. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    nice work on this case man!! although i'm not using the ion, i still like the zotac build. Currently using the geforce 9300 itx-wifi, and no problems so far.
    @Geowal19
    I work for a company that makes sieves. So tonnes of scrap mesh (stainless steel of course :))
    You want some? I don't pay for postage either, so i can send you some. What size you looking for? No guarantees, but i'll definitely see what i can find. Such a shame to see it scrapped. I almost cry everytime i walk past the bin.
  7. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    If you'd reconsider the possibility for another (a.k.a. separate-from-pump-top) reservoir, you could free enough space above the pump that there'd be room to put the fans in the inside of the case. Makes it more compact that way. But this is just a suggestion, based on your scetches - I don't know how that would play out in real life.
  8. elGafas
    elGafas Myopic
    2 Jul 2009
    It looks like i can put the fans inside the case...
    And look what just arrived in the mail:
  9. ringo
    ringo What's a Dremel?
    14 Jun 2008
    cool case!
  10. stuartwood89
    20 Aug 2008
    Looks so much better with everything inside the case.
  11. Nutman
    21 Oct 2008
    Glad to see you ran with my wish and tried to ft the fans inside the case. It just looks so much more clean, I think.
    Oh, and those fans just look perfect. I'm definately getting 6 of them for my next mod (colour scheme: white w./red trimmings and chrome details) - too bad they're so god damn expensive, but sometimes it's just worth it, hehe.
  12. elGafas
    elGafas Myopic
    2 Jul 2009
    Thanks!
    Agree.
    Now I can put a handle on the top :D
    Res+Rad arrived:
  13. elGafas
    elGafas Myopic
    2 Jul 2009
    Time for an update, hardware is on it's way :D
    Ioncito v 2.0
    I'm starting the case over again to fix some details I don't like from the first build, and now I can show you how I built the frame.
    This is what I ordered:
    EVGA GeForce GT 240 SuperClocked, it's a bit larger than the Zotac GT240.. but it's more powerful:
    Specs: http://www.evga.com/products/moreinfo.asp?pn=512-P3-1242-LR
    ZOTAC IONITX-F-E Intel Atom 330:
    Some old scrap alu, mesh and angle:
    Manual miter saw:
    First angle profile with some 45° cuts:
    Both profiles with mirror cuts:
    This cut is for curving the top bezel:
    And these are for the 90° angles:
  14. elGafas
    elGafas Myopic
    2 Jul 2009
    Bending:
  15. sentek
    sentek What's a Dremel?
    5 Jul 2009
    such clean bends, very nice :D
  16. elGafas
    elGafas Myopic
    2 Jul 2009
    Thanks!!
    This piece will go in the front:
    Fileing+Sanding
    Some filler:
    Sanding:
    Primer:
  17. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Beautiful bends nice craftsmanship! How did you get such precise bends? Did you bend the curve around something or is it all free hand? The Logo is a nice touch too. Keep up the good work.
  18. elGafas
    elGafas Myopic
    2 Jul 2009
    Thanks! I used to work at a handcrafted spring factory, I do my bendings free hand :thumb:
    Front and Top plates:
    Sanding + bondo to fix some scratchs and holes:
    2 component Epoxy
    My super caterpillar piston:
  19. elGafas
    elGafas Myopic
    2 Jul 2009
    Since this V2.0 is a "gaming version", it's a bit larger:
  20. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    oi! Dont mind if i steal this:
    Excellent craftsmanship, and very educational for a fabrication n00b like myself. Moar please! :D
