Scratch Build – In Progress Ioncito v2.0 [Update TODAY]
Discussion in 'Project Logs' started by elGafas, 27 Oct 2009.
  1. ednismod
    ednismod Minimodder
    15 Oct 2007
    That is sweeeeettttt!
  2. elGafas
    elGafas Myopic
    2 Jul 2009
    Thanks for your comments.
  3. elGafas
    elGafas Myopic
    2 Jul 2009
    Assembly test:
  4. shakka65
    shakka65 What's a Dremel?
    17 Jan 2010
    Like Chico and the Man would say "Looking Good" incredible mod keep going.
  5. elGafas
    elGafas Myopic
    2 Jul 2009
    Thanks shakka!
    Teaser:
    Still can't find a Laing DDC or compatible pump and the case is almost done :S
  6. elGafas
    elGafas Myopic
    2 Jul 2009
    Motherboard cooling mod:
    The mod consists in replacing the factory thermalpad and thermal compound. For this I used Tuniq TX2 and a 0.75mm copper sheet.
    It's really easy to remove the heatsink, just remove the 4 screws from the back and it pops out.
    Here you can see how the factory compounds look like:
    Closer:
    After cleaning the factory stuff we proceed to replace both compounds.
    Tuniq TX2 and copper sheet in place:
    Now the temps (It's really hot in this room couse it's summer, 35°c)
    Before the mod:
    After the mod:
  7. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Nice progress. Outstanding craftsmanship, its great to see that people have this kind of talent. Keep up the great work!:thumb:
  8. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Is it me, or did you completely move away from watercooling this rig?
    I mean, I still see a rad, a res and I also see that you're looking for a Laing DDC, but I also see improving the heat dissipation of the stock heatsink on the motherboard, the RAM is aircooled now AND I also see aircooling on your GPU.
    So, what's the deal here? Whatever happened to that custom block for the motherboard? Isn't that one going to return, even though it's a different motherboard? And what about the RAM cooler?
  9. elGafas
    elGafas Myopic
    2 Jul 2009
    I'm still going to watercool this baby, changed the RAM cause the OCZ sucked at performance and modded the heatsink to practice some OC till I can get a pump.
  10. elGafas
    elGafas Myopic
    2 Jul 2009
    Sorry I'm not updating as I used to... I'm having time/cash problems...
    Here you can see the result of hours and hours of sanding and fixing scratchs and holes... smooth and rounded bezels/edges.
    I just love the effect of Enermax Cluster's white light on the hardware.
    TODO List:
    Cut the back plexy window.
    Sidepanels.
    Alu Grills.
    Case feet.
    Build the HDD cage + case floor.
    Buy a Laing DDC pump + some new fittings.
    Buy a SSD to reduce even more the power consumption.
    Get a Job to afford all from above.
  11. Nutman
    21 Oct 2008
    Sweet - looks really good with the Enermax fans inside the case. ;)
    Quick question: Is it your camera, or do those fans actually have BLUE light? I find it a bit of a shame that they don't come with plain white light, now that they're coloured in such a nice, bright white colour.
  12. elGafas
    elGafas Myopic
    2 Jul 2009
    It's the camera, I hate KODAK!!!!
  13. elGafas
    elGafas Myopic
    2 Jul 2009
    Rad grill:
    Needs fileing and sanding.
  14. stonedsurd
    11 Mar 2009
    :jawdrop:
    How did you do that? Fretsaw?
  15. Nutman
    21 Oct 2008
    Looks really cool!
    How much air it'll actually allow to pass through is a totally different story - sometimes modding is not so much about practicality, but a matter of aestethics. ;)
  16. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    Lovin' this worklog! Good luck with finding a job dude!
  17. Evenge
    Evenge Minimodder
    16 Sep 2006
    That rad grill looks awesome! :rock:
  18. elGafas
    elGafas Myopic
    2 Jul 2009
    ScrollSaw with metal cutting blade.
    Hehehe :rock::rock::rock:
    Thanks!
    Thank You.
  19. elGafas
    elGafas Myopic
    2 Jul 2009
    Pump, Delphi DDC1A-VC:
    Blue led + Blue UV water:
    A few pics of the sidepanels while I lethercoated them:
  20. Nutman
    21 Oct 2008
    Dude, you badly need a new camera ;)
    But the rest looks really good, as usual.
