Apple iPad RDP Client
Discussion in 'Software' started by BennieboyUK, 21 Sep 2012.
  1. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    Hi Folks
    Can anyone recommend me a decent RDP Client Application for the iPad? I am looking for performance over functions, I have a keyboard so on screen keyboard is not needed.
    Thanks:thumb:
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    not sure about ipad, but on iphone I use itap rdp
  3. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Does rdp mean remote desktop something (a guess)?.
    If so splashtop works really well for me. It even works with windows 8, and has wake on lan.
  4. Snubbs
    Snubbs CustomPC Migration victim....
    27 Mar 2009
    I have used a few, however found "PocketCloud" to be the best of the bunch.
    The free version allows you to save 1 rdp connection, and is set at 1024x768. The paid version gives you extra resolutions and unlimited saved connections iirc. Also has VNC support.
  5. Booti
    Booti Minimodder
    17 Jan 2011
    I use LogMeIn to view my server desktop (and various other customer PC's) remotely from my iPad
    App is free, and LogMeIn is either free, or a small charge for extra features (which is dont think you will use from an iPad, such as remote print and file transfer)
  6. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    irdesktop for ipad (was free when i got it) excellent simple rdp app.
    others that are handy are:
    logmein ignition
    mocha vnc lite
  7. lcdguy
    lcdguy Minimodder
    25 May 2004
    at my last job we rolled out some ipads and decided on 2x client for the rdp client of choice. Mostly because the client is free. However RDP is less than ideal on an ipad.
  8. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    I use Logmein for when am using 3G and use "jump" when in the house, this can probably be used on 3g but logmein works just fine
  9. m3rk
    m3rk What's a Dremel?
    21 Nov 2012
    I use the 2X app on my iPad ... it's free and within it you can setup your own RDP sessions.
