Networks ipconfig error
Discussion in 'Hardware' started by FanaticJr, 14 May 2005.
  1. FanaticJr
    FanaticJr What's a Dremel?
    14 May 2005
    my friend just reformated her computer with windows xp and after changing the network settings to work with roadrunner nothing happens. so i go into camandline and type ipconfig and all i it says is windows ip configuration and nothing else. i also get a failed to query tcp/ip connection error. anybody know why this is happening?
  2. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    installed network card drivers?
  3. FanaticJr
    14 May 2005
    no its built in so its not a nic
  4. Haddy
    Haddy World Domination
    22 Jan 2002
    still needs drivers...make sure its installed properly.
  5. FanaticJr
    14 May 2005
    where could i download some drivers. i dont have any cd cause i had a new motherboard installed and i didnt get the cd for the built in features that it had
  6. Haddy
    22 Jan 2002
    look in the system information (accessories -> system tools -> system info) and find the motherboard's name (should be in the bios name)..
    Then you just need to go to the makers website adn they should have the most up to date ones...somwhere on their website..
