ipconfig woes... FIXED
Discussion in 'Tech Support' started by scimmy, 11 Jun 2008.
  1. scimmy
    scimmy Minimodder
    17 May 2005
    Hi Guys
    l've got a problem with a Dell Dimension 4600 with an Intel Pro/100VE lan. Win XP Home
    l'm getting an error msg about limited or no connectivity. l try to repair the connection but l'm told that the PC can't renew its ip addy. Typing ipconfig /renew give an error msg about not being able to do so..
    Help !!!
    Many thanks
  2. monkeybone
    monkeybone What's a Dremel?
    28 Jan 2005
    Are you using a router or connecting directly to a dsl/cable modem?
    If you are connecting to a router, you may need to power cycle your router.
    If you are connecting to a modem, then it may be an issue with your ISP.
    If you give us more info, we may be able to give you more precious help.
    Monkeybone
  3. fathazza
    fathazza Freed on Probation
    20 May 2002
    sounds like your routers dhcp isnt on? (assuming you have one)
    either turn it on or set the ip manually
  4. Golygus
    Golygus Minimodder
    9 Oct 2003
    I've seen a few Intel network adapters that have refused to obtain an IP since a windows update a couple of months back, try downloading the latest drivers from Intel's website.
    You could also try a different adapter.
    Hope this helps
  5. scimmy
    scimmy Minimodder
    17 May 2005
