Motors iPhone + car audio - how did you do it?
Discussion in 'General' started by Combatus, 11 Aug 2010.
  1. Combatus
    Combatus Bit-tech Modding + hardware reviews Staff Super Moderator
    16 Feb 2009
    Okay so my headunit is on its last legs and I'm trying to come up with ways I can just use my iPhone to play through my stereo instead of using a hard disk/USB stick like I do at the moment with my Blaupunkt headunit - not very easy to navigate music.
    I've never seen a good FM transmitter, we've have everything from £10 to £60 here and they're all crap so that rules that one out. Would prefer not to use the aux in either as I already have one cable charging my iPhone.
    How do you play your MP3 player/ipod/iphone through your car speakers?
  2. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
  3. JunkersUK
    JunkersUK Great chieftan o' the puddin race
    1 Aug 2010
  4. Nexxo
    Nexxo Queue Jumper
    23 Oct 2001
    My car has a proprietary iPod connector. Can you get one for yours?
  5. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I do believe almost all Pioneer headunits have support for an iPad adapter. It may cost a bit, though.
  6. line2008
    line2008 What is this "dremel" you speak of?
    29 Apr 2009
    i got a eonon dvd unit that an ipod can connect straight up to.
  7. Puk
    Puk (A shrewd and knavish sprite)
    23 Mar 2002
    I have a two year old pioneer headunit, it has a direct input for iPod that you can control on the headunit itself. I have an old 40GB classic that i bought with a buggered screen that lives in the glovebox, i just take it in and resync it everynow and then, I have absolutely no other use for it, so with the broken screen it made a really cheap storage device and you always have a massive music collection on tap :)
    The headunit also has two auxiliary inputs for non iPod connections which is pretty useful, i used this for my incarpc when it was under the chair, twin 3.5mm jack inputs for when the misses plugs her non-ipod mp3 player in when i have to listen to her **** music.
    But mainly in regards to an iPhone. I have had a few iPhones and the latest firmware allows me to play music whilst its connected to the headunit via bluetooth so no wires required, this is handy for my latest music, the headunit also has an inbuilt handsfree with a mic that ive located at the top of the "a" pillar trim, the phone rings through the speakers etc when someone calls, mutes the music and you look like those idiots talking to themselves in their cars everyday :)
    Check pioneers website for the options then find a second hand one on ebay, mine was only a couple of ton, has many outputs, pre-amp's etc, sounds bloody great =D
  8. Evenge
    Evenge Member
    16 Sep 2006
    There is many headunit manufacturers who offer direct Ipod/Iphone control. Alpine headunits have support for Ipod's, not sure about Iphone but I believe those should work as well if you buy unit with updated software.
    My alpine headunit has it's own connector for Ipod cable which would enable me to control my whole audio system with Ipod. So that's the way how I would do it.
  9. Tec_
    Tec_ New Member
    26 Feb 2008
    like Evenge said Alpine all the way.
    my head unit
    it works with my iphone 4
    Evenge likes this.
  10. Brett89
    Brett89 Active Member
    15 Dec 2005
    Alpine all thew way as said above, got mine 2 years ago now, IDA X-100
    sorry for the blurry phone pic, ignore the CD player. Had it for 2 years, not a single problem. Audio sounds infinitely better than through any FM/tape thing you'll get. Cannot recommend this style product enough.
    Evenge likes this.
  11. Elton
    23 Jan 2009
    Get a headunit with an Aux out. And work from there. You can navigate your songs via ipod.
  12. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Apple have a habit of making changes in their hardware/software revisions which stop new devices working with head units. My Alpine is temperamental with iphones for example. I have a double din pioneer which has full ipod control works as a blue tooth hands free kit too.
  13. badders
    badders Neuken in de Keuken
    4 Dec 2007
    I have one of these, and it's fine. Especially for only a tenner.
  14. Combatus
    16 Feb 2009
    Hmm I'm not convinced! Only because I've tested loads and the sound quality is poor compared to other methods.
    @Elton - I will definitely get a new headunit with Aux in just in case the direct control gets iffy.
    Thanks for the Alpine recommendations everyone, I think I'll probably go down this route.
  15. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    I've got an Alpine unit with the ipod adapter - it'll charge an ipod Touch (but not my iphone for some strange reason) and it'll usually play/control the music from both my ipod touch and iphone.
    I say usually, as it's developed a fault where it will randomly lose the connection to the Touch and give an error code on the radio display and where as I usually listen to my music shuffled it'll change it back to alphabetical order :wallbash: it could be the cable though, so I intend to nick my brothers (he had the same model radio in his old car) and see if it's that.
  16. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    I have one of these in the Jag:
    http://www.caraudiocentre.co.uk/product_m-kenwood-ddx8024bt_p-24199.htm
    And one of these in the Golf:
    http://www.caraudiocentre.co.uk/product_m-kenwood-kdc-bt50u_p-26036.htm
    Allows me to plug in my iPhone or any USB mass storage and play music. The one on the Jag also accepts SD cards, and supports Video out from the iPhone / iPod
    Both units also allow BT audio streaming, and Handsfree calling - and can be connected to your steering wheel controls with the correct interface (I've done this in the Jag)
    [Edit] link to pics of the Jag install: http://jaguarforums.com/forum/showpost.php?p=168962&postcount=53
  17. GreatOldOne
    29 Jan 2002
    That'll be down to the Alpine charging the iPod via the Firewire pins on the dock connector. The iPhone (and later model iPods) can't charge via the Firewire pins, as apple shifted everything to USB charging.
    What you need is one of these:
    http://www.cancomuk.com/Brand/Griff...od-and-iPhone-3031-FWUSB&ref=5681a404afd60a8d
    or one of these
    http://store.apple.com/uk/product/TS696LL/A
    They both do the same thing - take the 12V FW power and convert it to 5V USB power on the correct dock pins.
  18. Unicorn
    25 Jul 2006
    I've used a bluetouch kit with excellent results (flawless audio quality, and firmware upgradeable via USB to support new Apple devices) since I started driving.
  19. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    cheap radio transmitter hooks my creative zen touch to my stereo, very old CD head unit (Panasonic) to stock Volvo speakers. Good enough for audio books and such.
    TBH I find it nicer to listen to the radio whilst driving, music can change my mood to much, either causing me to hard and fast, or fall asleep with no middle ground.
