News iPhone iOS 4 released
Discussion in 'Article Discussion' started by Sifter3000, 22 Jun 2010.
  1. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    3G jailbreak is working; check the dev team blog.
  2. rollo
    rollo Modder
    16 May 2008
    3G and 3GS were given native unlock support and it's built into the iPhone 4 already
    Jailbreak is totally diffrent and will be a few days at least before we see the phones jailbroken again
  3. Fod
    26 Aug 2004
    sorry, i meant jailbreak AND unlock.
  4. Guest-16
    Guest-16 Guest
    :D :thumb:
    I'm waiting for the 3.1.3 w/ 05.12.01 jailbreak + unlock as well that was promised with the 4.0 launch.
    Oh, rollo - so if I upgrade I can use any SIM as default now?? It's only the unlocking I'm after.
  5. Fod
    26 Aug 2004
    if you're with O2 you can fill out a form on their website and they'll unlock it for you. wait a week or so for it to go through, sync with itunes and robert is your father's brother.
    http://shop.o2.co.uk/update/unlockmyiphone.html
  6. rollo
    rollo Modder
    16 May 2008
    yes id assume as much thats how i read it but hmm judging by fods post perhaps not
  7. rollo
    rollo Modder
    16 May 2008
    What do I need to do?
    First, complete the unlocking form. It will take up to 14 days for your iPhone to be unlocked and we'll text you to confirm the unlock request.
    Then place a non-O2 sim into the iPhone and connect to iTunes via a USB cable. iTunes will confirm that the iPhone has been successfully unlocked.
    Having trouble unlocking your iPhone? Visit our FAQs to find out more.
  8. gavomatic57
    gavomatic57 Minimodder
    23 Apr 2009
    How's everyone's battery life? Mine seems to have taken a tumble...(3GS)
  9. kenco_uk
    28 Nov 2003
    Jailbroken 4.0 on 3g. Multitasking works great! Mail is improved no end, no more press-press-press, read, then back, back, then press-press.. etc.. Seems responsive enough. Just restoring apps now :)
  10. Fod
    26 Aug 2004
    er... the 3G doesn't support multitasking?
  11. rollo
    rollo Modder
    16 May 2008
    you can get it on a jailbroken phone
  12. rollo
    rollo Modder
    16 May 2008
    downloaded some new apps gavo but i give it a full charge before i went to bed woke up and it was around 96% used to be around 89% so an increase if anything
  13. do_it_anyway
    do_it_anyway Minimodder
    24 Apr 2009
    Actually, as far as I understood, you ARE allowed your NHS.net account on a personal mobile. Because of the way the emails sync you can only view them while connected, and if you lose your phone, you log onto your NHS account, remove the lost device, and the account automatically "deletes" all the emails OFF the lost device.
    Pretty Swish.
    Correct me if I'm wrong?
  14. Nexxo
    23 Oct 2001
    UhmyeahOK. I think I should mention, Kamikaze-X, that I am a member of the Stakeholder Engagement group of NHS.net. Not only are we allowed to sync to iPhones (and the manual on NHS.net tells you how), but some of the very techheads who built and maintain NHS.net use iPhones too. :)
    do_it_anyway is correct. Although it stores synced emails on the device (so I can still read them if there is no signal), if the account is blocked or deleted stored emails are wiped at the next sync attempt. The account also enforces the access lock on the iPhone and locks the device after 5 minutes of non-use (you cannot disable this). If you lose the iPhone, you just log on to NHS.net and remote-wipe the device of all NHS.net emails, contacts, calendar data and account settings.
  15. Nexxo
    23 Oct 2001
    It only happens if participants reply.
  16. kenco_uk
    28 Nov 2003
    Not officially, no.. :)
    Can't get terminal to run and also can't install unsigned apps through itunes.. I'm sure there'll be a fix :) sbsettings runs well.
    Multitasking actually works really well. I can see why it isn't officially supported as the free ram does dwindle a fair bit when running a fair few apps.
  17. SpeedLegion
    SpeedLegion Minimodder
    23 Jul 2009
    Updated this morning and been running all day!
    works great, seems to runa lil quicker then the old OS :S but yeah upgrade now!
  18. Fod
    26 Aug 2004
    pwnagetool for 3G, 3GS (on the jailbreak train) and iPod Touch 2G is out now! Go get your jailbroken iOS goodness now!!
Tags: Add Tags
