Blogs iPhone Review: Helsing’s Fire
Discussion in 'Article Discussion' started by Sifter3000, 27 Jul 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. pimlicosound
    pimlicosound New Member
    7 Sep 2007
    Joe, I agree, this game is good fun, mainly for the presentation. Although, right now, I'm hooked on Chop Sushi! That game is a better puzzler and the presentation is even better - a perfect parody of typical Japanese bizarreness.
  3. melone
    melone New Member
    28 Jul 2010
    When ordinary townsfolk start to disappear Dr. Helsing and Raffton head to the Shadow Blight to eradicate the monster who caused the townsfolk to mysteriously vanish and who happens to be the infamous Dracula. Helsing's Fire is a new kind of puzzle game that’s designed to work on the iPhone and iPod touch. The actions can get frantic and puzzles are intriguing.
    Gameplay
    Helsing's Fire isn't your ordinary puzzle game. The gameplay is much more exciting: you use torches and tonics to destroy Dracula's minions on your way to destroy the blood sucking monster himself. In Helsing's Fire you have a torch to illuminate your surroundings. Depending on the monster's color you use the same colored tonic to eradicate them. It would have been easy, but there are obstacles in your way that can block your light, and in darkness, there are usually monsters lurking behind. The gameplay becomes challenging and very intriguing here since you have a very limited supply of tonic, so you have to use them wisely while navigating through the light and darkness. If you happen to run out of tonics and still have monsters left in the screen then you must exit the level and start all over again.......Electronic Book Reader Kindle Wireless Reading Device (6" Display, U.S. Wireless)
    Killing Dracula's horde isn't everything. You can also get achievements depending on how many monsters you slay. And there are ton of monsters! Helsing’s Fire has a sprawling 90 levels in 3 worlds. If you pride yourself as a monster killer, you’ve come to the right place to hone your skills. Different monsters also possess special abilities. There are 13 types of monsters including werewolves, ghosts, vampire bats, mummies and more, each of them harbor a deadly weapon. Some can shoot arrows and others can attack you're torch, making the game more challenging and a lot more fun!
    After you beat 30 levels you'll unlock survival mode. In survival mode you must destroy all monsters before time runs out and if it does run out then you lose. It’s game over if you run out torches or tonics also. So you really need to plan where you are going and use your tonics efficiently and accurately.
Tags: Add Tags
