Apple iPod -> Computer Transfer
Discussion in 'Software' started by uwannabigmak, 23 Sep 2005.
  1. uwannabigmak
    uwannabigmak What's a Dremel?
    30 Dec 2004
    Ipod-Computer transfer
    I am currently using WinAmp to synch my ipod and computer files. I am using the ipod with two computers. I can get the files from the 2nd computer to the ipod easily. I cannot, however, get the files off the ipod onto the computer. It seems to have options to allow for this in winamp, but it doesn't import them. I am using ipod plugin v1.21.
  2. hacker 8991
    hacker 8991 What's a Dremel?
    8 Jan 2004
    PodPlus will get the job done, but you might be able to find something else that is free.
  3. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    You're not supposed to be able to retrieve music off the iPod, because that could lead to mass piracy. :p
    But there are several programs that do this. The best known is ephPod, which has a large array of tools, one of them allows you to copy music from the iPod to a folder on the computer (I kept having problems with it where it wouldn't copy every song, I don't know why not). There is probably a plugin for Winamp that allows you too, but I don't know of any off the top of my head. PodUtil is a very cool program that will copy songs from the iPod too. You can also try SharePod, CopyPod, or Anapod Explorer.
    As you can tell, a lot of people want to do this so there is a large variety of programs you can use. :p
