News iPod finallly gets Vista fix
Discussion in 'Article Discussion' started by Tim S, 11 May 2007.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    I'd clap if sony released some vista drivers soon HMPH
  3. mclean007
    mclean007 Officious Bystander
    22 May 2003
    The non-working bugs may have been the fault of both Apple and MS, but IMO any hardware that can be irreparably bricked by a new OS should be blamed on the manufacturer. With the exception of the installation of new firmware (which should in any event be capable of reversal), there should simply be no way by which software can break hardware. As such, I blame Apple.
    Out of interest, does anyone know if Apple will, without charge, repair / replace iPods that have been damaged in this way?
  4. bilbothebaggins
    bilbothebaggins What's a Dremel?
    1 Sep 2006
    Maybe Apple though it worth the p*** off iPod users to give Vista some more bad press.
    Then again, maybe the iPod and/or M$ guys are just incompetent.
    ... dunno which is worse :D
  5. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    broken link?
    and surly it was a mastermind plan of MS to break the iPods! hooza! :D
  6. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    the MS wanted to break iPods plan is ludicrous.
    they would simply go out and buy another one and likely stop using vista, which would be a major hit to microsoft, and as such would be a stupid business decision.
    Gates & co are smarter than that.
  7. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    they took all this time to fix that? crud.....
  8. paul_s57
    paul_s57 What's a Dremel?
    23 Dec 2005
    Does this fix work for both 32-bit and 64-bit versions of Vista?
  9. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    heh i dunnoabout regular ipod but my shuffle works just great with Winamp.... screw iTunes...
  10. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    MS releases updates for both (unless it's platform specific), so yes.
  11. GoodBytes
    20 Jan 2007
    When I used Vista RC2 public beta, I had no problem with iTunes nor my ipod, everytihing was working flawlessly.
  12. Boswell
    Boswell Minimodder
    23 May 2005
    "Let us hear your experience with the bugs in our forums."
    Link puts you through to the forum homepage and not here...
  13. mattthegamer463
    26 Nov 2004
    I didn't even know there was a problem with the iPods, my Nano worked perfectly with iTunes and I had no clue I could have bricked it during that time! Thank god I never update my songs. Stupid Vista, I can't wait until I'm dual-booting XP.
  14. Bluephoenix
    3 Dec 2006
    same for me, probably because I use the obvious 'eject' button in itunes, rather than 5 more commands through the other ejection system...
  15. GoodBytes
    20 Jan 2007
    yea, that is what I was doing too. Or right click on the removable drive inside "Computer", and click on "eject".
Tags: Add Tags
