Apple iPod Pass-through Charging Cable
Discussion in 'Software' started by Evilbob, 15 Apr 2006.
  1. Evilbob
    Evilbob What's a Dremel?
    28 Apr 2001
    I've just purchased an Ipod Camera Connector and I've noticed that as expected when using the ipod battery really drains away from all the constant hard disk activity, has anyone ever seen a charger/usb cable with a pass-through connector to allow you to use the dock for other purposes simultaneously. I have managed to find a battery pack made by a company called Nyko (http://www.nyko.com/nyko/products/?i=41) that supports this but have been unable to locate a charger.
  2. Firehed
    15 Feb 2004
    Nothing I'm aware of. However if you're in a situation where you have access to a charger, surely you could grab a laptop or something and transfer the files from the camera to that instead. Should be a bit quicker and not ravage your battery.
    Instinct tells me that it's not safe to have one if it's even possible.
  3. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
  4. Evilbob
    28 Apr 2001
    Thanks for the suggestions but Im trying to be more portable for my holiday this year so and a laptop isn't really budgetable right now, I'll try posting in the other forums and see if I can find anything suitable else I might just stump for the battery pack, I managed to transfer 60 odd pictures on a half full battery, granted they were 6mp JPEG images.
  5. seebul
    seebul Minimodder
    9 Aug 2005
    Be cheaper and easier to buy a bigger card for your camera wouldn't it?
  6. AJB2K3
    12 Dec 2005
    It recharges just like the iPod does of the usb.
  7. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    I would buy a dock connector and experiment, just check if the ipod will charge when transferring files.
