Apple iPod stuck on 'Do Not Disconnect'
Discussion in 'Software' started by crazybob, 29 Dec 2006.
  1. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    My little brother got an iPod for Christmas, and it worked brilliantly until today. I'm not sure what happened, exactly, but now the thing is stuck at the 'Do Not Disconnect' screen.
    EDIT: According to Apple's excellent help section, the reset procedure is to slide the Hold switch on and back off, then hold down menu and select until the device resets. This worked magnificently and the problem is gone.
  2. kylelnsn
    kylelnsn What's a Dremel?
    19 Dec 2006
    go on google, and searhc how to reset your ipod, it happend to me, reset it and i will work fine, its liek press play and middle or summin search on google and u will find how to reset after this it will work fine1
  3. Atomic
    Atomic Gerwaff
    6 May 2002
  4. z3rb
    z3rb +4 str +4 stam
    6 Nov 2006
    Just let the batery die...
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    Resetting it is quicker and easier.
  6. savage
    savage What's a Dremel?
    7 Jan 2007
    Yep I had the same problem the other day and i just took it off turned it off then plugged it back in and it was fine.
