Displays IPS or 120 hz
Discussion in 'Hardware' started by czm, 16 Sep 2011.
Thread Status:
Not open for further replies.
  1. thehippoz
    thehippoz New Member
    19 Dec 2008
    yeah that's a good ips monitor far as ghosting goes, if your looking for a compromise
    looks like the op is interested in gaming though.. the 120 will definitely be better
    see I used to be a cs head back in 1.6.. played competitive for awhile so I know what's up.. the casual gamer doesn't know what it's like to shoot in a fraction of a second against a player just as good.. it's pretty crazy the gap between elite and casual- quake showed this quite a bit more
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    I'd take a better looking picture over a slight improvement in how fast I can see things. But it is down to the person, I owned a "fast" TN panel for a while before I got my IPS and I can't notice a difference timing wise.
    And I apologise if I sounded overly aggressive, I fear I may be turning into GoodBytes about monitors lol
    And thehippoz, yeah as long as you buy a decent one which you will be for 1920x1200 hopefully, then the difference will become even more marginal.
  3. Deders
    Deders Well-Known Member
    14 Nov 2010
    I remember easily being able to see the flicker on some 50-60Hz CRT's, could even see the difference between 60 and 75Hz on my old CRT. I think you may be confusing Refresh rate with framerate, and even then that is up for debate.
  4. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    If you could see faster than 50Hz then you would have seen old light bulbs flickering... :p
  5. Deders
    14 Nov 2010
    Well i could see the 60Hz screens flickering.
  6. longweight
    7 May 2011
    And people did :p Not many but as previously stated not everyone's vision cuts off at the same level, some can see higher rates than others.
    As I said before, IPS is MUCH better at 90% of things, TN panels win on response time so would be better if you want to potentially gain that tiny edge in FPS games.
  7. noizdaemon666
    15 Jun 2010
    I think that both of you are right, I too can see certain screens flicker at 60Hz (old ones), but I can't see light bulbs flicker...unless I flick the switch really quickly lol
    I may have to google this....
    Edit: Idea, have an IPS panel with a 10bit display....without a colour processor, like a TN panel. With a flux capacitor to get the colours from the future, now. Great colours, far faster response :D
  8. longweight
    7 May 2011
    You won't see a GLS lamp flicker at mains voltage, the old switch start fluorescent lamps flickered a lot due to them turning on and off from 100% > 0% > 100% whereas GLS lamps follow the AC wave and "gently" dim up and down.
  9. LennyRhys
    LennyRhys Oink!
    16 May 2011
    You can't really compare a screen to a lightbulb though - the light doesn't change, but the screen of a game changes all the time making it easier to notice (to a point).
  10. longweight
    7 May 2011
    I was only commenting on someone else's post :worried:
  11. jizwizard
    jizwizard Well-Known Member
    24 Dec 2010
    right here we go. i have a benq 2410t 120hz monitor. now before everyone jumps on me i use it in fps games and i can tell the difference if i switch it from 60 - 120hz. just seems smoother. couple of mates have them to and they are competion grade gamers and they love it. yes its not the best at reproducing colours, took me a while to calibrate it. but to me it would make no difference as im totally colur blind lol
  12. Showerhead
    Showerhead New Member
    11 Jan 2010
    Surely an old fashioned tungsten lightbulb wouldn't flicker though as their would still be a residual glow as the voltage fluctuates through 0V
  13. longweight
    7 May 2011
    That was my point (might not have been that clear though!) you only see flicker on fluorescent or metal halide lamps.
  14. czm
    czm New Member
    17 Apr 2009
    Well I am thinking I am swaying more towards the 120hz over the Dell IPS.
    As I use my PC for gaming..it would make sense
  15. Showerhead
    11 Jan 2010
    Best bet is to see if there are any stores in your area that stock an IPS and a 120Hz monitor so you can compare them side by side.
  16. longweight
    7 May 2011
    If you are near London then Yoyotech is well worth a visit to have a look at IPS vs TN panels.
  17. MSHunter
    MSHunter Well-Known Member
    24 Apr 2009
    I went from a 2ns Samsung gaming monitor to the Dell U2311 (6ns I think).
    1) I have never seen any "in-put lag"
    2) I score much better because I can see into the black (there are levels of black you will not believe)
    My next monitor will be a bigger Dell Ultra sharp.
  18. MSHunter
    24 Apr 2009
    Might not be the best example but I am sure there is an Apple store near you. iMAC's use IPS.
  19. longweight
    7 May 2011
    Not everyone will see input lag and I know I certainly don't on my U2711 which has relatively bad input lag.
    Once you go IPS black you never go back.....
  20. czm
    czm New Member
    17 Apr 2009
Thread Status:
