Windows IR assistant
Discussion in 'Software' started by peteone, 3 Aug 2002.
  1. peteone
    peteone Minimodder
    5 Jun 2002
    Well my IR package turned up today thanks to meblin. I got winamp plugin to run no problem but I am having problems running IR assistant. The learn page has a percentage bar on it which is supposed to increase as the programe learns, but when I point my remote at it and press the buttons nothing happens .
    Someone help please!
    pete.
  2. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    I got a remote too, but having trouble getting it going, which plugin for Winamp did you use??
  3. peteone
    peteone Minimodder
    5 Jun 2002
    I got one of either the winlirc site or the media texx site. But personaly I would use IR assistant cos its free and you can moove your cursor round, shut down, volume with the remote, and it controls most windows apps. It also comes with a quite good help file. melbins site has links to winlirc and uICE. And a guide to setting up.
    http://www.meblin.karoo.net/
    http://www.irassistant.com/dotcom/v_current/
    The mistake I made was not having winlirc running at the same time as the other software. Duhh
    If you have any more probs. Il be happy to help.
    Pete.
