IR ports anyone?
Discussion in 'Hardware' started by scoob8000, 5 Nov 2002.
  1. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    IR ports anyone?
    im googled out.. anyone know anyplace that sells IR transcievers for my mobo? ECS K7S5A.. its got a lil 5 pin header on the board.. i need to locate the cable with the IR led in it..
    the pinout goes:
    1 FIR
    2 n/a
    3 +5v
    4 GND
    5 IRTX
    6 IRRX
    would it be possible to make something from radshack parts?
    -scoob8000
  2. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    best to talk to meblin, as he sells these things, and has looked into it quite deeply...
  3. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    Yep, Meblin is the man! Have a look in UK For Sale for his thread!:)
  4. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Here is some info with vendors.
    http://www.pcremotecontrol.com/irda.html
    I think you may be able to build it from RS parts, but there is one chip on it, I'll check tonight for ya to see what chip it is.
    If I have time I can reverse engineer the schematic for ya.
    I have this one:
  5. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Another vote for Meblin, he should be able to help you out
  6. scoob8000
    17 Feb 2002
    hrmm am i totally blind or cant i find meblin's post in either of the forsale forums?
    -scoob8000
  7. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    [edit - double post]
  8. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Using one of his creations now to control winamp and so on
  9. ZapWizard
    19 Sep 2002
    Well Serial Infared and IRDA is pretty different.
    I have built the serial infared similar to Meblin's for my Car MP3 Player project. It works perfectly for receiving remote controls.
    But if you want to sync a PDA or connect to another PC you need true IRDA.
  10. scoob8000
    17 Feb 2002
    DOH! :(
    mebbe id just be better off buying the data cable for my celly..
    -scoob8000
  11. scoob8000
    17 Feb 2002
    wewp! i managed to find what i need on fleabay.. too bad i didnt find anything until i tried searching for IRDa instead of IR header or IR ports.. :)
    17 bucks for serial port hookup transciever.. not too bad i guess.. i coulda got a USB model for about 30, but this is good 'nuff for me and my ringtones.. :)
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=2067817491&rd=1
    -scoob8000
  12. Meblin
    Meblin Supposed IR God!
    5 Mar 2002
    Damn missed out on a perfictly good sale :waah:
    Yes I sell IR Serial devices for remote control of your PC
    I calso make IR motherboard headers to enable comunication with phones and othe IR devices (but not remote control units)
    Meblin
  13. scoob8000
    17 Feb 2002
    sorry mang.. so you could make something like that i could plug into my mobo header and mount in my case? depending how much that might cost i will still do that for my other PC.. :)
    did ya get my email btw, the smtp server was fooked earlier..
    lemme know
    -scoob8000
  14. Meblin
    5 Mar 2002
    Yep got your mail and then looked at this post. I have sold a couple of the IrDA motherboard headers in the UK for £9 including P&P and would beable to sell it to the US for say US$16 (Inc shipping). This would get you the IrDA device on a lead about 50cm long with a connector suitable for the motherboard you are using.
    I think I have bits to make 4 of these at the moment so if anyone else wants one let me know :naughty:
    Meblin
  15. ZapWizard
    19 Sep 2002
    Well after looking at it at home, it pretty simple but the chip is built into the transmitter/receiver.
    The part number is IRM-100 You can search google for prices.
    I found it for $15 here:
    http://www.provantage.com/scripts/go.dll/-s/fp_66609
    Or support the team and buy from Meblin
  16. Meblin
    5 Mar 2002
    The only comment I have to make about that is that it's designed for an ASUS mb. The headers on other mother boards are not always the same (e.g. my ECS K7S5A has the 5 pins in 2 rows of 2 and 3 pins where the ASUS is all in a row). The connectors I make are created for each motherboard individually :D
    Meblin
  17. scoob8000
    17 Feb 2002
    hrm.. would ya happen to take paypal?
    -scoob8000
  18. Meblin
    5 Mar 2002
    Yes :naughty:
    Am going to upgrade my order page soon to include IrDA orders
    Meblin
  19. cderalow
    cderalow bondage master!
    23 Jan 2002
  20. scoob8000
    17 Feb 2002
    yikes, the same thing is on fleabay for 16 bucks.. :)
    anyway, i alerady ordered a irda serial device, but
    im still gonna buy a mobo specific one from meblin to mount inside my other PC.. just to support the team.. :)
    meb, lemme know when your ready and ill order..
    -scoob8000
