Case Mod - In Progress Iron Man Case Mod. Computex Show 2012-Video
Discussion in 'Project Logs' started by BLUEHORSESTUDIOS, 6 Apr 2012.
  1. BLUEHORSESTUDIOS
    BLUEHORSESTUDIOS I haven't lost a finger yet!
    19 Apr 2010
    Fixing update...
    Waynio likes this.
  2. Waynio
    Waynio Relaxing
    20 Aug 2009
    Superb, you must be well seasoned to doing this caliber of modding :D when I make sweet progress I can't hold back how happy I am about how things are going which I suppose clutters my project log, :duh::hehe: yours is so neat & professional. :cooldude:
    This is all excellent very high standard, every update is brilliant mate. :):clap: rep
  3. argonn
    argonn What's a Dremel?
    19 Apr 2012
    I love the details painted on everything. Very professional:thumb:
  4. failariel
    failariel What's a Dremel?
    7 Feb 2012
    i love it!!!!
  5. BLUEHORSESTUDIOS
    19 Apr 2010
    Iron Man Project sponsored by MNPCTECH and Thermaltake
    http://mnpctech.com
    On todays update Im going to construct the leg flares/counter measures that come out of his upper thigh. Ill scratch build this using 00.80 styrene,red LEDS and a few products form Evergreen Styrene.
    Lets get started
    Im going to start with a 3 1/2 inch ABS plumbing fixture, red LEDS and a panel of v-groove by Evergreen Styrene.
    After marking out the areas for the LEDS, I use my drill press to cut out each hole and secure the v-groove with weld-on adhesive.
    I use round stock by Evergreen Styrene that I shape with my heat gun and glue into place.
    I add a paint finish using Flat Black/Gunmetal on the v-groove and Flat Aluminum on the small gears.
    I secured the LEDS with a strip of hot glue.
    The top and bottom panels are constructed and will be painted with a red metal flake.
    The flares will be attached to the back panel once I completed the leg armor that goes underneath.
    The panel is build from several layers of ABS/Styrene.
    http://i1114.photobucket.com/albums/k531/BlueHorseStudios/DSC00380.jpg
    Masked off and painted with the first coats of color.
    The first coats are applied, now ill detail the gears with a fine brush.
    I mock-up the panel to see if everything is fitting correctly.
    In this wide shot you can see the missile systems too.
    The 12v wires leadind to the LEDs are sleeved in Kobra sleeving and passed thru the case door.The two 3/4 inch screws holds the flares in place.
    I added a paint graphic on the interior door panel.
    The 12v wire leds to the molex hub that I scratch build and painted.The cable tie-downs are made from round stock and ABS plastic and secure with epoxy to the panel.
    With the overhead lights in the shop cut down you can see the LED illuminated.
    On my next update Ill start on Iron Mans Helm that will be mounted on the front bezel.
    Stay Inspired and Keep Creating
  6. BLUEHORSESTUDIOS
    19 Apr 2010
    Thanks everyone and sorry for the issue with the pics from photobucket.Fixed!
  7. rak500
    rak500 Minimodder
    22 Aug 2009
    The airbrushing is unbelievable, the details too!
    Fantastic work!!!
  8. BnZn
    BnZn What's a Dremel?
    13 Apr 2012
    Absolutely incredible attention to detail! If the work on the outside is any indication, i can't wait to see what happens on the inside! :clap:
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    Now with descriptions, loving it. :)
  10. Baguette
    Baguette What's a Dremel?
    6 Aug 2010
    Absolutely fantastic! I just can't wait for the final result!
  11. Cheapskate
    13 May 2007
    Sweet rig.:D -Gonna look like Iron man fell in a car crusher.
  12. BLUEHORSESTUDIOS
    19 Apr 2010
    I got started today by tearing down the chassis and prepping for paint. The concept for the interior is to paint it like the Mark 1 suit seen in the above pic.
    http://mnpctech.com
    I received these copper rivets from mnpctech that Ill use to put the chassis back together. The copper combined with the steel,alloy and aluminum will create the feel of the Mark 1 suit Tony Stark built while in captivity.
    I painted the back panel in a red metal flake from Duplicolor,and Gold leaf from Tamiya.
    The chassis is painted in gunmetal also from Duplicolor.
    The colors really complement each other well and will be sprayed with a clear coat in a later process.
    I sanded down the black powdered coat to bare metal and sprayed it with a flat steel from Duplicolor.
    The same process was also applied to the motherboard tray with graphic and weathering added.
    I used vinyl graphic letters to create the stencil and sprayed it over with a flat black with my airbrush
    After the panels have dried from the sealer , Ill reassemble and add some touch-up and graphics to the chassis.
    Stay Inspired and Keep Creating!
    Waynio likes this.
  13. matiss
    matiss Minimodder
    24 Jun 2010
    Gorgeous...absolutly gorgeous. I would be happy if I had 10% of you when it comes to painting.
  14. Ragequit
    Ragequit What's a Dremel?
    26 Apr 2012
    Man, this is effing epic! Keep up the good work!
  15. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    AWESOME Ron!
    and Great use for the pop rivets! I'm planning the same thing for upcoming project that will emulate steel riveted plating. Paint alone, wouldn't give it that realism I'm going for :thumb: ...and carriage bolt heads are great too...
  16. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    The attention to detail and skill in fabrication and airbrushing is just stunning, such a awesome case, me wants :O
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    Who couldn't with perfect modding like this :jawdrop::dremel: excellent stuff mate, loving it. :D A +rep is overdue again :D
  18. Cown
    Cown Minimodder
    25 Feb 2012
    I'm speechless...
  19. BLUEHORSESTUDIOS
    19 Apr 2010
    The copper rivets look amazing against the gunmetal finish,I was concerned at first with the concept but it really turned out well.
    Thanks Bill
  20. BLUEHORSESTUDIOS
    19 Apr 2010
    Thanks again for everyones support here. My deadline is coming up fast,and I still have the helm and chest piece to finish before I can ship this back to Thermaltake. Ill be updating this thread once the project is complete. Thanks for your patience.
