Case Mod - In Progress Iron Man Case Mod. Computex Show 2012-Video
Discussion in 'Project Logs' started by BLUEHORSESTUDIOS, 6 Apr 2012.
  1. joyadam10
    joyadam10 What's a Dremel?
    30 Jan 2012
    nice to see your post your post
  2. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    This is wery good! love the build, hopes you finish it in time! =) i'll hang here til it's done... :D
  3. BLUEHORSESTUDIOS
    BLUEHORSESTUDIOS I haven't lost a finger yet!
    19 Apr 2010
    Project sponsored by Thermaltake and MNPCTECH
    http://mnpctech.com
    Today Im going to get started on the chest piece and case window.
    I scaled the chest piece to the size I wanted then made a paper template that I later transfered to 00.80 polystyrene.
    After each piece is cut out I make a paper mock-up and begin the raw construction.
    All the panels are assembled and modelers putty is applied.
    After some finish sanding and body work the chest piece is ready for primer.
    Two coats of primer is applied ,sanded then a final coat is added.
    Since the chest piece will be removable, i modded the back too.
    The chest piece receives the first coats of color and slowy comes to life.
    With the back side finished, Ill now spray the front.
    I painted the front with a red metal flake from duplicolor and the locking bolts in a polished aluminum.
    The Arc Reactor will go inside the opening.
    Looking down you can see the gears that I created in a earlier step.
    On the interior of the case I created bead welds to simulate the Mark 1 suit that Tony Stark first built while in captivity.
    Mark 1
    I dont like to out-source any of my work but I had this backlite vinyl graphic made-up and installed in the case window. Two 12in blue CC tubes illuminate it from with in.
    In the home stretch.. I just have the helm to finish ,mount and detail everything up and He's complete. The May 25th deadline is looking pretty good.
    Stay Inspired and Keep Creating!
    Waynio likes this.
  4. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Top notch modding buddy once again!!! Mod on man you rock!
  5. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    This is such excellent work. You are truly a master of the airbrush.
    I hope some company steps up and hooks you up right.
  6. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Ron is my Modding Hero :D
    I cant wait to see it finished!
  7. BLUEHORSESTUDIOS
    19 Apr 2010
    Thx Angel..really appriciate your support and kind words.
  8. BLUEHORSESTUDIOS
    19 Apr 2010
    Man I could really use a new airbrush, my Iwata is starting the die-out on me.
  9. BLUEHORSESTUDIOS
    19 Apr 2010
    Super Heros all around Bill:D Thx for your support and encouragement.
  10. kelmannen
    5 Feb 2011
    Wow! that image is super! fits in really well! :) and the airbrush work is super as usual =)
    (Ps. Do you know that you can multi-quote? u don't need to make several posts.)
  11. BLUEHORSESTUDIOS
    19 Apr 2010
    No, i didnt know that you can multi quote.How is that done?
  12. jhanlon303
    7 Sep 2006
    Click the middle right button on the posts you want to quote.
    Then the quote button.
    The highlighted ones show up in one post
    john
  13. bulldogjeff
    2 Mar 2010
    How the hell did I miss this one. I've just been through the whole build. WOW!!! This is amazing, going to be so cool, I just love it. Top modding dude:thumb:
  14. ozzylow
    ozzylow What's a Dremel?
    22 May 2011
    Love your builds and your work, really stands out from others. I would like to be able to work with the polystyrene sheets. Is there any tutorials with this stuff, any sites that you would be able to link me to with the basics.
  15. BLUEHORSESTUDIOS
    19 Apr 2010
    You can watch my youtube videos of the biohazard build ,parts1-14 and it goes into great detail of how to work with styrene.
    http://youtube.com/ronleec1
  16. kelmannen
    5 Feb 2011
    as the man said, go to his youtube channel, those videos are really good! :) (and an AWESOME build!)
  17. maestro0428
    maestro0428 Master Modder
    24 Jun 2010
    Awesome, just awesome. Keep up the great work!
  18. Arkaridge
    Arkaridge What's a Dremel?
    14 May 2012
    woah woah woah. I can't wait to see the end product.
  19. theoeyeo
    theoeyeo What's a Dremel?
    27 Nov 2011
    one of my favourite mods of all time here..
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    Definitely 1 of mine too :D incredible modding, love it. :dremel::rock::clap:
