Scratch Build – In Progress Iron Revenge II (By Herodj) - Sleeving!
Discussion in 'Project Logs' started by Herodj95, 25 Apr 2012.
  1. Herodj95
    Herodj95 What's a Dremel?
    9 Sep 2011
    hi guys, i'm back! :)
    next the first edition of my mod, i want to start the second edition of my Iron Revenge.... there's the first iron: http://forums.bit-tech.net/showthread.php?t=216456
    now, there i want to create a new case different from the first mod....
    There I build a chassis with iron's tubolar and varius aluminium plate, etc. I want to have a modular structure, fast to build/disassemble! ;)
    start to mod!! :dremel:
    while i wait to build the frame i start with little work.... cut the first plate of aluminium!
    there's the cut what I want to do!
    now, go!! :dremel:
    and this is the first result.... i must finish it!
    so, modify it!
    finish the first plate!! :)
    for today, that's all! What do you think??
    Big thanks to my sponsor!
    Bye bye
    Hero
  2. Herodj95
    9 Sep 2011
    anyone?? :rolleyes:
    now go ahead with the mod! Today I have welded the frame! The frame meausure 40 x 50 x 20 and builded with 2cm x 2cm of iron's tubolars!
    That's the photos!
    and now i can mount the power supply bracket!
    Now I cut the first plate.... An aluminium plate of 0.8mm!!
    Take the measure
    Cut and test it on the frame!
    the first plate is completed, next i'm going to glue it on the frame but after the painting! :thumb:
    That's all fot today
    Bye bye! :)
    The_Crapman likes this.
  3. Herodj95
    9 Sep 2011
    Good notices for you, i have a sponsor!! :clap:
    continue with the mod.... now i have get a mobo tray!!
    and try it on the case....
    next i'm going to cut a plate for it ;)
    so, i want to weigh all....
    not much for the moment ....
  4. Herodj95
    9 Sep 2011
    Now i have get some sheet metal waste free :naughty:
    There are steel sheets of 1.5mm ....
    start to cut and sand the first plate!!
    That's a good difference!
    and try it on the frame!
    Ready to cut!! :dremel:
    for the cut i'm going to use these dremel wheels!
    Yeesss!! :clap:
  5. Herodj95
    9 Sep 2011
    The second steel sheet is for the mobotray....
    Try the tray! :D
    having 2 minutes of spare i'm going to try some led effects on the case...
    that's all for the moment.... what do you think about?? :)
    bye bye :thumb:
  6. bulldogjeff
    2 Mar 2010
    I like the look of this one...Nice metal work skills.
  7. Herodj95
    9 Sep 2011
    Thank you bull! :)
  8. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    i second bulljeff =) godd skills and small full atx =)
  9. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Gotta love a bit of heavy metal! :rock::rock::rock: Look forward to seeing what comes of this! :)
  10. Herodj95
    9 Sep 2011
    Thanks kelmannen :thumb:
    Thank you Crapman :)
    So, in the evening new up! :rock:
  11. Herodj95
    9 Sep 2011
    too long time that i don't up my thread! Sorry :duh:
    ok, now i start to cut a scrap of metal sheet.... give some meausure!
    and now cut!
    Bend it!
    fix all in the case!
    i wanted to leave 1cm for a thing that you can see next!
    behind, the metal sheet is supported by 2 angulars...
    so, fo today that's all! :D
    bye bye!
    Hero
  12. Herodj95
    9 Sep 2011
    so, continue with the up on my worklog! :)
    i want a front panel different from standard.... i want to have a good air flow for my fans!
    Idea :naughty:
    first tests of bend!
    what i want!
    now, that's all!!
    See you soon :rock:
  13. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    Oooh!
    I am always in awe of the people working with steel - that stuff is hard to cut, hard to shape, and hard to do anything with really. Very nice work so far, and I'm looking forward to see how this evolves. Excellent. :thumb:
  14. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Great Mod needs a strong frame :thumb:
  15. Herodj95
    9 Sep 2011
    so, the steel is hard to work when you haven't the right tools.... ;)
    Thank you so much Journeyer :)
    Yes kappa!! A stron frame! :D :thumb:
  16. Herodj95
    9 Sep 2011
    Good morning all! :)
    Today i show you some up!
    start whit this metal strip that meausure 4mt x 10cm and 0.8mm.... I'm going to use this depth to bend better the other "spine"!
    I divide the strip in 4 pieces to have more manageability!
    and now i cut in 16 pieces!
    :D
    and next i trace the other cuts!
    from this.....
    to this!
  17. Herodj95
    9 Sep 2011
    - Bending -
    after cutting i'm going to bend all spines...
    that's the result!
    hold they....
    and do some hold at the structure...
    and now with rivets i'm going to fix all spines...
    :D
    for the moment this is all...
    I wait your comments :)
    Hero
  18. dietje1908
    dietje1908 What's a Dremel?
    12 Jan 2009
    a lot of work always pays off , nice man very nice :)
  19. Shurika
    Shurika Minimodder
    9 Mar 2012
    It`s what like should the SilverStone Raven look! Dangerous case
  20. aio
    aio Minimodder
    8 Jun 2012
    also reminds Aerocool Predator.
    but steel scales better :)
