irql_not_less_or_equal recurring bsod
Discussion in 'Tech Support' started by fathazza, 10 Sep 2007.
  1. fathazza
    fathazza Freed on Probation
    20 May 2002
    im getting a recurring bsod
    it also mentions usbechci.sys in the bsod.
    my system is
    GIGABYTE GA-MA69GM-S2H AM2 AMD 690G HDMI Micro ATX AMD Motherboard
    Amd X2 BE-2350
    OCZ DDR800 single 1gb stick. (the stuff with the tacky camo job)
    samsung spinpoint 500gb sata.
    hauppaugge nova t 500 pci tuner card.
    hiper 350w psu
    my inbuilt card reader from my silverstone case.
    running win xp sp2
    i changed the irq of the tv card to a free one as i thought that might be the cause but it is still happening
    I understand that this is a catch all exception and that it could be ram, drivers, other hardware or basically anything at all..
    i have done a 3 pass memtest with no errors.
    I think i have all the latest drivers except for the tv card as it wont open the ones i download properly
    can anyone suggest what else to do?
  2. IAmATeaf
    IAmATeaf Minimodder
    9 Jun 2006
    When does it BSOD, during boot, during use? I'd try removing some hardware and run with the minimum to see if it'll actually boot and run. Also did you upgrade any drivers recently, if you did then try doing a roll-back to the previous version.
  3. kenco_uk
    28 Nov 2003
    hmm.. might be a pain, but have you tried unplugging the card reader?
  4. fathazza
    20 May 2002
    it always boots fine (and very quickly i might add)
    It largely seems to do it when im recording tv in gbpvr (but this is pretty much the only time i have the computer on)
  5. fathazza
    20 May 2002
    it is a pain but it might not be a bad idea. it came with 3 usb headers, one with the normal 9 pins, and two others with 6 pins each which confused me a little so i guess i may have made a mistake with the pins and that might be causing it?
    The annoying thing is its a random error, it might happen twice in half an hour. or be fine for 4 or 5 hours... so testing to see if ive fixed it is annoying
  6. fathazza
    20 May 2002
    hauppauge is busted again!
    21 page thread about people experiencing the same problems as me with a nova T 500!
    http://www.hauppauge.co.uk/board/showthread.php?t=9888
    Thats the 2nd time ive bought a card from them that had serious implementation issues. Never again!
  7. Bluestar76
    Bluestar76 What's a Dremel?
    11 Sep 2007
    if you read teh bsod it will tell you the offending module, eg USB.sys
    Normally this is crappy third party drivers that cause this BSOD.
  8. herbs
    herbs Nobody but us chickens
    7 May 2001
    It is a hauppauge issue not just the nova-t 500 it happens on my usb nova-t stick. The newer nova-t500 is not meant to suffer from this, maybe get hauppauge to swap it out.
