Memory Is 16GB worth the extra cash
Discussion in 'Hardware' started by badermans, 7 Jan 2017.
  1. badermans
    badermans What's a Dremel?
    8 Apr 2006
    Quick Question
    I have a first gen i7 with triple channel DDR. I really want to upgrade the ram as i only have 6gb.
    I have seen duel channel 8gb sets for around £50 or 16GB sets for around £80. I will be saving up for a new PC and donating the current on to my younger sister in the next 6 months
    Will i see a massive difference from 6-8gb or is it worth stumping up the extra cash and getting the 16GB.
    Thanks
  2. Vault-Tec
    30 Aug 2015
    Get the 16gb. There are quite a few games now that need more RAM.
  3. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    I don't know if it's a "massive" difference, but the consensus seems to be that 16 GB is the place to be right now, but that 32GB is still overkill.
  4. Pookie
    Pookie So this is permanence, love's shattered pride.
    4 May 2010
    Triple channel kits are hard to come by, are you going to ditch a channel and run 2x8GB?
  5. law99
    law99 Custom User Title
    24 Sep 2009
    I play ark a lot and sometimes memory usage on my PC with chrome open in the background I've seen my GPU memory at 400mb off from full, and the system ram at 19gb out of 24. Since upgrading ram I've had less stutters also in gameplay
    The world is using more ram.
  6. LennyRhys
    LennyRhys Oink!
    16 May 2011
    It depends what OP's intended use is. For general use (including gaming) I'd see no reason to have more than 12GB in an X58 system, especially if you're not considering a long term upgrade. I upgraded to 24GB just over a year ago because of the software that I use daily.
    So my recommendation is to grab a cheap 3x2GB kit or even a 2x4GB kit off ebay and use that until you upgrade your rig. There's no point spending £50 on RAM if you can pick something up for £25.
  7. theshadow2001
    3 May 2012
    I would say its not worth spending any money on if you are upgrading in 6 months. Unless you think your sister would require the RAM.
  8. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Tbh I wouldn't bother getting either option, I'd put the money in the pot for the new system.
  9. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    Assuming you're not heavily overlocking, and your current memory is 1066 or 1333 DDR3 (posting a CPU-z screenshot of your mem would help), don't bother trying to find a triple channel kit, just grab 3x of these and call it a day.
  10. nimbu
    nimbu Modder
    28 Nov 2002
    I never bothered with buying triple channel kits when I was on that socket. I had various corsair xms 4gb modules different versions same clocks. Mixed and matched and had 24gb running without a problem.
  11. badermans
    8 Apr 2006
    Yes i was planning to running 2x8gb or 2x4gb
    Mostly use my PC for playing eve online and older titles. But would love to start playing new titles like Rome 2 and CIV5. I used to play Cities in motions 2 but on larger maps or sprawling cities, the game used to dump me back to windows as i didn't have enough RAM.
  12. Gareth Halfacree
    Gareth Halfacree WIIGII! Staff Administrator Super Moderator Moderator
    4 Dec 2007
    I run 16GB and still swap; my next build will be 32GB. I'm not gaming, though: I'm editing high-res images while having a silly number of browser tabs open alongside the occasional VM, and also dumping all my temporary files into RAM (ah, tmpfs, how I love thee.)
  13. ewitte
    ewitte What's a Dremel?
    13 Jan 2017
    I've ran low a few times on 32GB I'd go to 64GB if the prices didn't increase 40% :(
  14. DeckerdBR
    DeckerdBR Minimodder
    9 Mar 2011
    I upgraded from 8 to 16 and it made a big difference to the performance of some games, namely Ark Survival Evolved & Space Engineers, both of which easily use between 10-14 gig of ram depending on settings used.
    It is also handy when you wan't to have 2 games open at the same time. What Heresy is this I hear some say?
    Well say your playing a '1 life per round' style of game (like world of warships) with a group of mates and you get taken out early on in the match, you can alt tab to say CIV5/6 and play a few turns while you wait, with little performance impact to either game.
    Go for it! :)
  15. SuperHans123
    SuperHans123 Minimodder
    27 Dec 2013
    As with everything else tech, it's all about your personal use cases.
    I have 16GB of RAM running @ 1866MHZ and I have no issues.
    That said, I only use my PC for browsing and playing games, not at the same time.
