Graphics Is a 7870 worth the extra ~£20 over a 7850?
Discussion in 'Hardware' started by Smellyhead, 1 Oct 2012.
  1. Smellyhead
    Smellyhead Member
    29 Jun 2011
    Hey,
    Pretty simple question would you guys say a 7870 is worth the extra money over a 7850 to play GW2/WoW/CSGO and odd bit of BF3 at 1080p? I also fraps my WoW and GW2 play so would ideally like to be able to keep high fps on high settings.
    Ones I'm looking at are;
    MSI 7870
    7850
    Thanks
  2. PorkChops
    PorkChops New Member
    11 Dec 2011
    I have no experience with fraps. But my 7850 overclocked as far as itll go with standard catalyst control center runs all of the above at 1080p with plenty of room to spare. So by the definition that the 7850 will almost definitely do everything you want it to do, then the 7870 would not be worth it. If you get lucky and get a nice chip on the 7850 too, then you should be able to use the msi afterburner software to bring that card well above the performance of a stock 7870.
    Sorry for not necessarily answering your question, but hope i helped regardless.
  3. narwen
    narwen narwen
    6 Aug 2010
  4. Elton
    23 Jan 2009
  5. iajo
    iajo New Member
    27 Oct 2010
    I'm in a similar position as a casual gamer playing at 1080p 7850 2gb seems to be around £170 and ive seen 7950 3gb less than £220 with the 7870 somewhere in between. Job to know what you need and what is overkill sometimes but the price brackets are very narrow with three cards within a £50 range.
  6. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    Pick yourself a financial limit and get the best you can for that amount. The better you can get, the longer before you will need to upgrade.
  7. Zero_UK
    Zero_UK New Member
    12 Aug 2008
    The 7870 will give you probably similiar power to a well overclocked 7850 - 5-10% more performance and also going by Bittech's review of the 7870 it is also more power efficient.
    Unless you are extremely short on money and are just scratching together money for a 7850 I think the extra £16.83 is worth it. That card out classes the GTX 570 in just about every scenario. I'm using the GTX 570 currently and I am running all my games 1080p max aside from DayZ which I think is more CPU limited.
  8. Smellyhead
    Smellyhead Member
    29 Jun 2011
    Well I wanted to spend £170 since I need a sound card aswell but with the 7870 at £178 I thought i may stretch if it was worth it.
    Is that a no?
  9. law99
    law99 Custom User Title
    24 Sep 2009
    £8 for more... I'd do it. Don't be silly. It's £8.
    If you were buying car tyres and the ones that will grip extra in the wet and stop you sliding into the nearest tree at 70mph were £8 more, it would be a situation commonly referred to as a "no brainer".
  10. narwen
    narwen narwen
    6 Aug 2010
  11. caiusfatuous
    caiusfatuous New Member
    27 May 2010
    hi all,
    Are XFX card's any good?
    Am looking at getting the 7950 over the GTX660TI
    Thanks
  12. Shirty
    18 Apr 1982
    I fully agree with going for the best you can afford. I have a GTX670 (with the potential to overclock well past 680 speeds) in my machine even though I only game at 1920 x 1080, simply because in the next few years new games will start to test the card at said resolution. I would hope the card will last me a good 3 or 4 years, after all I made the GTX280 last from launch until earlier this year.
    Spend the additional beer money now and you'll reap the rewards in the future. Such is life for the PC gamer.
    3lusive likes this.
  13. caiusfatuous
    27 May 2010
    are Nvidia cards worth getting or should i get an AMD card instead?
    Still pondering between the GTX660TI and the HD7950
  14. will_123
    will_123 Small childs brain in a big body
    2 Feb 2011
    My 7870 is giving me just under 7950 once I over clocked it. Mines is the Twin Frozr version. Im happy with it.
    Stays very cool and gives me the results in ARMA. Its giving me around 60 frames most of the time on the highest graphics. Sometimes i dont get that on chernaus, but i do playing takistan.
  15. law99
    24 Sep 2009
    Is there voltage tweakery on these cards yet?
    I saw with the 7850 you couldn't add more... which was a shame as I'd imagine you could push it really hard if you could.
  16. Shirty
    18 Apr 1982
    I believe in setting a target price, then shopping around to get the best possible deal. For example, the EVGA GTX670 F.T.W. I bought on the marketplace last week would have cost me at least £320 new from a reputable dealer, but I got it for £260 delivered, so a £60 saving. Considering it has 33 months transferable warranty remaining (it's only 3 months old) I think it was a bargain, especially considering at stock it trades blows with a vanilla 680.
    I actually bought a new 660Ti for myself and the 670 was for a friend, but have agreed to swap them over as I game at a slightly higher resolution and they were just about the same price.
    As for Nvidia vs AMD, neither is really better, as you will find some deals on both sides that push favour in either direction. For guidance, the Tom's Hardware hierarchy is usually a pretty good indicator of where things currently stand.
  17. caiusfatuous
    27 May 2010
    but lets say i have the budget for either the HD7950 or the GTX660TI and the 7950 is almost 50dollars cheaper.
  18. Shirty
    18 Apr 1982
    Get the 7950 imho. Nearly as good for much less dollar.
    Only things to look out for are the cooling solution and warranty, a loud, hot 7950 might not be as pleasant to live with as a quiet, cool 660Ti*. Let us know which cards you're looking at and we'll give you the true geek's opinions :)
    *That's not to say the reference cards are much different in terms of heat/noise, just that different brands and coolers can swing things...
  19. caiusfatuous
    27 May 2010
    well for the time being im looking at the one frm XFX for the one from MSI cost as much as the GTX660TI frm MSI...
  20. Shirty
    18 Apr 1982
    Which XFX model specifically? There are four different XFX 7950s. Links would be good, but model numbers would help too.
