Build Advice Is Asus p8p67 Deluxe, LGA1155, DDR3 Re-usable???
Discussion in 'Hardware' started by neil_b, 18 Jan 2021.
  1. neil_b
    neil_b Minimodder
    20 Jun 2009
    I've got a (admittedly old) PC that Asus (the manufacturer of the P8P67 Deluxe mobo that the PC's built around) say will NOT run W10 (which I need it to), and that the Mobo needs upgrading to something newer (I'm not wedded to Asus at all btw). The key specs are (i.e. the parts I'd rather not bin!);
    DDR3 Memory - 16GB (4x4GB)
    Intel Core i7-2600K 3.40 GHz
    MSI GTX 570 1280MB
    (and the Mobo is Asus P8P67 Deluxe mobo - LGA1155 socket (this is the part Asus say doesn't support W10 so it may have to go... and it IS old I know)).
    I've still got the case, PSU, graphics card, cooler, SSD's etc too.
    Can anyone recommend a new mobo that would be able to re-use the DDR3, i7 2600K and MSI GTX 570 - and probably most importantly, run latest W10? Or do I have to ditch the lot and build a new PC from scratch (which I'd be ok with if I had to do it)? The recycled/upgraded or new PC is to be used largely for Minecraft + live-streaming.
    Many thanks guys....
    N.
  2. adidan
    25 Mar 2009
    What do you mean won't run it?
    My second rig is an i7 3770 on an Asus P8Z77-M and it works perfectly fine (LGA1155)
    Edit: Your motherboard even has bios and driver updates for W10 64 (drivers i let W10 do itself as it's old gear though). It may be worth updating that bios if yours is older though.
  3. neil_b
    neil_b Minimodder
    20 Jun 2009
    They've said that the drivers for several of the on-board hardware elements won't work with W10. Is your P8Z77-M same vintage as my p8p67 ~2011?
  4. VictorianBloke
    VictorianBloke Man in a box
    31 Oct 2007
    I was happily running win10 on an older Core i5 720 and P55 board until about 6 months back, and still got it running on some old AM2 boards (including an ancient ASUS one) with no issues whatsoever and everything working. ASUS not officially supporting something doesn't mean it wont work as expected.
    The win10 upgrade process used to include a hardware scan that would highlight any known incompatibilities. Though not sure if that's still in there.
    If you have a spare drive to swap over you could always try a test install.
  5. adidan
    25 Mar 2009
    2012 I think.
  6. Ajbod
    Ajbod What's a Dremel?
    12 Dec 2016
    One of the computers in this house is a
    Z68-a3-b3 , I5 2500k, 16gb ddr3, R9 390x.
    windows 10 flies on that.
    i've run windows 10 on LGA775 boards with Q9400 and core2 duos.
    never had problems, maybe the odd niggle finding obscure drivers, but
    not many.
  7. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Ran Win 10 on multiple skt 775 boards without issues. It basically just find everything that is needed.
    This includes a Foxconn P45 ELA which is somewhat obscure.
    I would be very surprised if it didn’t work on a P67 board. Maybe some random onboard “thing” may not be picked up quite right but I can’t say I have experienced this in my own builds.
  8. Jards8595
    Jards8595 Minimodder
    31 Aug 2011
    I have that Mobo with an i5 2500k, 16gb ddr3 running win 10 Pro no problem, with a fresh install its actually really nice.
    I dont even know which bios im on, win 10 just worked.
  9. thewelshbrummie
    thewelshbrummie Minimodder
    29 Aug 2009
    I usually like & trust Asus but that's some straight up BS.
    It will work. And I doubt you'll have any issues.
    What Asus mean is that they only have an audio driver for that board on Win 10 whereas they have LAN/Chipset/Bluetooth/USB/Sata drivers if using Win7 and they're rather that you buy new parts from them so that you have full driver support.
    But Windows is pretty good at finding basic drivers that work.
    The P67 was the last high-end Intel Chipset not to have any support for USB 3.0. However, your board has an NEC controller that adds 4 USB 3.0 sockets. On Win 7 you would need the drivers as USB 3.0 support isn't built in. But USB 3.0 support is built into Win10 and from experience Win 10 is excellent at finding drivers that will work automatically.
    The only biggie that Win10 needs is SSE2 support which Intel introduced 21 years ago in 2000 with Pentium 4. Not all CPUs of that age supported it as at work 5-6 years ago we had one PC from around 2004 and while Win7 could be installed the Win10 auto update thing Microsoft added refused to run as the CPU didn't support the correct instruction set.
    Back on topic, in your case with a Sandy Bridge CPU, that's not an issue as all Sandy Bridge CPUs support SSE2. You should be absolutely fine.
    blackerthanblack likes this.
