Networks Is BT blocking port 5611?
Discussion in 'Tech Support' started by adam_bagpuss, 25 Nov 2010.
  1. adam_bagpuss
    24 Apr 2009
    Anyone got bt broadband to try this on
    I've tried several machines and several different routers and different bt lines all to the same effect.
    Port 5611 will not open I've also had trouble with other ports too
    Such as 5610 6060 6061 5552 3388 8866
    Anyone know if bt actively block ports or particular types of packets through their systems
    It's basically sending commands, audio, video for cctv
  2. Landy_Ed
    Landy_Ed Combat Novice
    6 May 2009
    You trying to connect to that port down your broadband to a specific host, or is it local to your own mini network through a BT router?
    If there's a specific host that folk can try connecting to that might garner more responses! some cmd line that we can try maybe?
  3. adam_bagpuss
    24 Apr 2009
    its for any WAN user
    so external to a single internal IP
    basically if anyone has BT broadband can they open port 5611 to any WAN user ?
    use ping.eu to check if its open .
  4. saspro
    saspro IT monkey
    23 Apr 2009
    Is it mapped to the correct internal IP & any firewalls on the device have that port open as well?
    Can you send me your external IP via PM to test?
  5. Hawkest
    Hawkest I got some 4GB new RAM
    22 Jun 2009
    Have you spoken to BT - JOKE!!!!
  6. adam_bagpuss
    24 Apr 2009
    how strange 5611 on 1 machine i have is magically open now and i havent done anything.
    but 5610 is closed !!!!!
    is everything is mapped correctly and firewalls have exceptions (even turned them off to test)
    ive sent PM with external IP
    cheers sas
  7. adam_bagpuss
    24 Apr 2009
    lol yeah several times of which im told everything is working as it should on thier equipment and they blamed the machine instead
    i told them ive tried several PCs and changed the router and its somehow still my fault.
  8. saspro
    saspro IT monkey
    23 Apr 2009
    Ports tested & results PC'd back
  9. Hawkest
    22 Jun 2009
    yeah, typical 1st line support at BT!!!
    oh and anyone that works at BT 1st Line Support thats reading this and "you" do a good job, i don't mean you!!
  10. saspro
    saspro IT monkey
    23 Apr 2009
    You wouldn't offend anybody. We all know BT 1st line support can't read.
  11. adam_bagpuss
    24 Apr 2009
    you said 5610 was closed but your other PM said 5610 was open ?
    it just about working but when i set it up 5611 was closed and other sites im settting up have had the same issue and they have BT broadband.
    thanks for checking sas
    lol cant rep you cause you were last person i gave rep to lol stop been so damm helpful
  12. saspro
    saspro IT monkey
    23 Apr 2009
    Sorry 5610 closed, 5611 open.
    You can save the rep for another day after you've issued some to someone else
