Is it a 300a?
Discussion in 'Hardware' started by Adam, 27 Jun 2002.
  1. Adam
    Adam Minimodder
    26 Jan 2002
    Where on the chip can I see if my celeron is a 300 or a 300a?
  2. George
    George Bah
    14 May 2002
    i dont think theres a way to tell my looking at the chip, if it dosnt say on the chip, then you will need to put it in a system to find out.
    .icecube
  3. Lazy
    Lazy Meow?
    13 Nov 2001
    have you looked on top of the chip? it might be in very tiny letters.
  4. Adam
    Adam Minimodder
    26 Jan 2002
    There's all sorts of numbers all over the chip but none say anything useful. I was thinking maybe there is some sort of code like the stepping code on athlons which could tell me. There must be someone here old enough to remember!
  5. Sgt. Gimp
    Sgt. Gimp What's a Dremel?
    11 Nov 2001
    If you look on the reverse of the card there should be a small white rectangle with two lines of text at the edge of the pcb. On my one the second line reads "300A/66 COSTA RICA" so that should be what to look for.
