Motors is it bad to use a solvent to remove dirt?
Discussion in 'General' started by xen0morph, 28 Jul 2006.
  1. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    my car has about 6 months worth of caked-on dirt and grease, a lot of it's due to using veggie oil as it sometimes gets split down the side when filling up and things just seem to stick to it. i was thinking about using a little bit of petrol or white spirit or something to shift the dirt...is this ok to do without taking the paint off? (what little paint there is left on this car i'd rather keep thanks :p)
  2. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    I would definaltely try hot water and dish detergant first.
  3. Krikkit
    21 Jan 2003
    Agreed - get the soft side of a scouring sponge and some fairy liquid on the job. That's designed to cut through veg oil. :thumb:
  4. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    Get a bottle of Gunk. Only costs about a fiver and will shift anything grimey or greasey without removing the paint too.
  5. Pookeyhead
    30 Jan 2004
    Agreed. Gunk! It can degrease an engine, so a bit of spilt veggie oil is no problem. once cleaned, some light rubbing compound and a good wax polish afterwards.
    Keeping your car well waxed should help prevent build up again.
  6. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Wash, T-Cut then polish.
