Graphics Is it dead?
Discussion in 'Hardware' started by freshsandwiches, 3 Jan 2017.
  1. freshsandwiches
    freshsandwiches Can I do science to it?
    9 Aug 2009
    Is my graphics card dead?
    I put a new card in and it works. Just want to make sure before I chuck it. It's the artifacting that tells me it's dead.
    Thanks.
  2. RedFlames
    23 Apr 2009
  3. freshsandwiches
    9 Aug 2009
    Thought so.
  4. Sir Digby
    Sir Digby The Supprising Adventures
    18 Jan 2009
    Do we still bake video cards?
    I think we should still bake video cards.
  5. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Well it won't make anything worse.
    Although if it's a new card it might scupper the RMA effort.
  6. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    RedFlames likes this.
  7. Vault-Tec
    30 Aug 2015
    If it's the 560ti in your sig get it in the oven.
  8. RedFlames
    23 Apr 2009
    I had 3 560tis go like that only one got baked [as the others were under warranty]... it still didn't work but it was worth a shot...
    4 MSI Twin Frozr 560tis [the 4th had a dud fan], all dead inside of 6 months... Haven't bought a MSI card since...
  9. freshsandwiches
    9 Aug 2009
    Yeah it's the 560ti in my sig.
    Running a 1050ti now. Will suffice for the mean time until I can afford to build a new pc.
