A/V Is it possible: Music=Speakers; Gaming=Headset
Discussion in 'Tech Support' started by jcrider, 6 Sep 2013.
  1. jcrider
    jcrider Minimodder
    27 Sep 2009
    All,
    Is it possible to play music through the speakers in a room so others can listen to it whilst someone else plays a game on the PC?
    I have Windows 7 and on board sound.
    I doubt it is.. but maybe there is some cunning way of achieving this??.. a second virtual desktop perhaps??
    Thanks in advance,
    JC
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    I looked into this with a friend who wanted the voice from game chat through his headset and the game sounds through his speakers and I believe the answer was a second sound card.
    So for instance you set the audio player, VLC e.t.c to use your onboard sound and then install a second sound card for the game audio or vice-versa. If you have a USB headset then you might be able to do it already since the USB headset is considered a second sound device.
  3. Andy Mc
    Andy Mc Modder
    23 May 2002
    I used to do something similar a few years back. Headset = Ventrillo, Speakers = Game.
    It was a PITA, routinely co*ked up and trying to fix it was a nightmare.
    But lancer is right in his reply, 2 sound cards needed. I set the game to use the default internal one and ventrillo to use the usb headset's.
  4. bigc90210
    bigc90210 Teh C
    7 Oct 2003
  5. John_Edward
    John_Edward What's a Dremel?
    21 Dec 2005
    You can do it with some integrated soundcards as well, such as the Realtek ones in Asus P5Q-PRO and GIGABYTE Z87X-D3H, but it requires your case to have a headphone jack in the front panel.
    1) Go to Control Panel
    2) Open "Realtek Audio Manager" (Or somesuch, differs a little)
    3) From top right, click "Device advanced settings"
    4) Select "Make front and rear output devices playback two different audio streams simultaneously"
    5) Open your program, in this case easiest would be the music player, got to playback/output devices, and select "Realtek Audio 2nd output"
    This is also great for using TeamSpeak with a mono headset, so you can keep your game sounds from your speakers as loud as you like and still hear everyone speaking perfectly. Just remember that the mic also picks the game sounds, so if you want to talk, keep the volume sensible :)
    If yours doesn't support this, the easiest and cheapest way is to buy a cheapo "3D SOUND" soundcard, that you can find _everywhere_ for a few bucks.
    [EDIT]
    If your programs or games don't allow you to change the audio device, one trick is to set one device as 'Primary', open the program, go back to the audio device settings, change the second card as primary, and open the other program.
    Most programs will require you to restart them before they start using the new 'Primary' sound device, so if you don't close them, they should keep using the old one.
  6. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    My daughter has her game sounds through her onboard and her headset for team speak and skype runs through an Asus Xonar DG 5.1 and works like a charm, has never caused her a single issue.
    I have a similar setup but my logitech Z10 speakers are usb so no need for a 2nd sound card for my headset.
  7. jinq-sea
    15 Oct 2012
    I do this with my rig - sounds in general come out of my main audio output, with the comms stuff being routed through my USB plantronics headset. You just have to tell whatever app it is doing the voice (teamspeak/steam chat/skype/whatever) to use the headset for audio!
    Easy as peas.
