Planning Is it possible to cut a TFT panel?
Discussion in 'Modding' started by silverdirk, 19 Mar 2009.
  1. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    I thought there would be rigid material on both sides. If not, ofcourse i'd agree with you to cut the thin one first :)
  2. Sushi Warrior
    Sushi Warrior What's a Dremel?
    20 Mar 2009
    I still don't get why you don't just cut it around an inch or 2 too big so you can't see any of the black, dead pixels. No complicated solutions, you'd just need an inch or 2 of extra space behind the mounting for the panel.
  3. frojoe
    frojoe What's a Dremel?
    17 Dec 2008
    Cutting an lcd to damage only 1 or 2 inches of pixels is no easy task, look how widespread the damage was in Smilodon's attempt.
  4. Richh999
    Richh999 Small Time Modder
    9 Oct 2008
    Maybe freezing it with ln2, to stop the liquid from running and then laser cutting it at the same time could work. I would try but I'm not allowed to take the ln2 out of the labs and too the laser cutter, sorry.
    I think your biggest problem is applying force to keep the layers together with out breaking the lcd. It would most likely be best to cut the glass last if you are going to cut it in layers.
    However I do believe that this is possible to do, or well I can't see why it wouldn't work...
  5. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    A small update on my second try:
    It was a complete failure. I was going along nicely. Leaving maybe 6mm of dead pixels along the end. After getting half way across the screen the cutting wheel on my Dremel dug in and ripped the layers apart ruining everything. :(
  6. AFX
    AFX "Bling" Silver Mountain 2
    19 Sep 2006
    Keep up the good work and better luck next time!
    I have a Compaq (i forget the model) but it has a 15in or so screen on it. but i fired the mobo. I could donate it if needed.
  7. frojoe
    17 Dec 2008
    sounds to me from that attempt, that this will be possible. just very difficult. I just don't know if it will creep over time. Keep trying though, and try to get some old lcds to try on, this could et expensive fast.
  8. docodine
    docodine killed a guy once
    10 Feb 2007
    Win thread. :thumb:
    Extremely doubtful that this would work, given that you only get one or two shots at this.
    I would say... Your e-peen would increase by about 3847209857x10^91304134 if this is successful.
  9. aglaser
    aglaser What's a Dremel?
    19 Dec 2008
    My first impression upon reading the title of this thread was that cutting a TFT display panel would be impossible. However, both of smilodon's attempts suggest to me that, in fact, it can be done. Both times, though there is obvious and widespread damage, the screen still functions (at least, I assume it does the second time -- he said there was just a 6mm strip of dead pixels at the bottom until his dremel caught). At this point, it's just damage control -- and my guess is that his second attempt failed from nothing more than bad luck. Interesting thread, look forward to more ideas!
    P.S. 3847209857x10^91304134 is not correct scientific notation! Correctly, it would be 3.847209857x10^91304134000000000. Geez, get your random numbers correct.
    Incidentally, though, I agree with the effect on his e-peen...
  10. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    Could the vibration from the dremmel cutting process be what damaged the pixels? Six millimeters is still a pretty big band.
    Clamping could be a problem as it does not evenly distribute the stress.
    Cooling the pannel as mentioned before might help, but how would the localized heating of the cutting process affect it?
  11. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
    I really think this could work. As long as you sealed the end of the cut. 6mm seems to be quite acceptable!
  12. talladega
    talladega I'm Squidward
    18 Aug 2007
    how about using a tile saw? VERY SLOWLY!
  13. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    I think a Laser cutter is the only way this could work. No physical stress on the layers and the heat would close the edge at the same time.
    Anyone has one around? :D
  14. Smilodon
    25 Mar 2003
    Hmm. Thinking about it, melting the plastic layers before cutting could help. Just drag a soldering iron on maximum temperature over the cut line. Then cutting it carefully. Could work. You would still get dead pixels a few millimeters from the edge, though. It's impossible to avoid.
  15. Grimloon
    Grimloon What's a Dremel?
    4 Sep 2008
    This is definitely an interesting discussion, I was just wondering if a hot wire cutter would be enough to seal the edges before you try to cut the glass backing? The temperature would have to be pretty high but it *might* be possible.
    Just a thought but if it works then you could use a common or garden glass cutter to snap off the excess, no need for diamond powder dremel wheels.
  16. Smilodon
    25 Mar 2003
    Even if the plastic is melted, it would probably still hold the glass together, preventing a clean score and break. Butting with Dremel would probably be a bit safer.
  17. sui_winbolo
    25 Sep 2004
    I want to see one of the mod gods with a frivolous budget attempt this. :D
  18. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    That seems to be what's happening, albeit with a slightly smaller budget...
    No, it's 3.847209857x1091304143, obviously. ;)
    (10x x 10y = 10x+y, not 10x*y)
  19. Splynncryth
    31 Dec 2002
    Car guys would cut safety by puring a little lighter fluid in the cut and lighting it on fire to deal with the plastic in it. I think the iron would have to be really hot for it to work instead.
  20. sui_winbolo
    25 Sep 2004
    ^^^math nerds. :p
