Electronics is it possible to hook 2 small comps to 1 PSU?
Discussion in 'Modding' started by Springs, 16 Jun 2005.
  1. Springs
    Springs Boing boing
    29 Aug 2004
    just woundering if its possible to hook up 2 computers to one PSU....
    got a 400mhz k6-2 and a 1ghz duron and was hoping to hook them up to one PSU as they are sorta weak computers..
    is it possible?
  2. foxx
    foxx What's a Dremel?
    5 Sep 2004
    Sure, nead to do a little soddering, but I dont see why it wouldnt work.
  3. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    It should work if you have a high enough wattage psu. The K6-2 doesnt take much but those bartons are power hungry. The only problem i could see would be with the power switches as in, which computer would control being on (and off). Im pretty sure you could just take out the green atx wire from the 20- Pin socket and wire it to a switch with a ground. With that, when you flip the switch (cant be momentary, has ti be toggle) the power supply will turn on and in therory both the comps too. Just dont forget if you want to shut them both down you would need to make sure each computer got to the "It is now safe to turn off you computer screen" (even XP has this screen) and then flip the switch. Other than that I dont see why it wouldnt work. Hope that helps.
  4. theshadow27
    theshadow27 What's a Dremel?
    23 Sep 2004
    yes, but why would you want to? by the time you found a second 24 pin ATX connector, you could buy a surplus PSU. you dont gain anything here...
  5. Springs
    Springs Boing boing
    29 Aug 2004
    well i no that one of the mobos has to be turned off manually.. but i dont no about the other one.... its commin in the post some time soon.... tbh i totally forgot about the green wire.. have to think about the wire...
  6. Springs
    Springs Boing boing
    29 Aug 2004
    its mainly to save space... ive got no room for 4 cases (as i have 4 comps)... let alone 2.. so to put them into 1 case and share power.. takes 2 cases and makes 1 out of it...
  7. pillow
    pillow What's a Dremel?
    16 Aug 2004
    if you have money to spend u could buy a shuttle psu (or two) and put everything into one case.
  8. nick01
    nick01 What's a Dremel?
    6 Nov 2004
    In most cases you can stack 2 1U supplies like http://www.istarusa.com/New Folder (2)/TC-1U25.htm into the space of the regular ATX (2U) supply. They are 2" longer than the regular supplies (8" instead of 6"), but smaller in all other dimensions. Of course, it is not the cheapest solution.
    I had trouble on the 3.3V line when I put two mobos on one supply.
  9. tm36usa
    21 Jan 2004
    Done even need a shuttle psu. A trip to newegg finds you this http://www.newegg.com/OldVersion/app/viewproductdesc.asp?description=17-103-143&DEPA=0
    I have one and it ran a 1.6ghz atholon with a cdrom, 2 Hds and misc lights and such. You could keep the psu for the one and just get this. If you didnt want 2 IEC connectors (the power plug) you could wire the one to the other. Very simple and cost effective solution.
    EDIT: Damn your in the UK, Let me try and find a UK retailer. BRB
    EDIT: Sorry mate, cant find anything with a quick google search and I got to go to dinner. I will look more when I get back.
