Windows Is it possible to increase tempo on mp3 files?
Discussion in 'Software' started by couzo, 8 Jul 2003.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    I would like to speed up some mp3 files i have and was wondering how I can do it any ideas woud be great
    Thanks
  2. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    My friend has a program called OTSjuke that allows you to do it - it provides a virtual mixing facility for mp3s I believe but is a commercial piece of software..... I don't know how much a licence costs but it is very good.
  3. ST8
    ST8 What's a Dremel?
    14 Feb 2003
  4. tk421
    tk421 Idiot.
    15 Jan 2002
    i used to use the DJS player to mix back when i had 2 sound cards ... worked pretty well ... if it can control tempo enuff to mix d&b im sure it will fit your needs
    http://www.deejaysystem.com/
  5. couzo
    26 Apr 2002
    tk421 did you use the mk1 player which is free? If so how do you go about changing the tempo? Also can you make it not change the pitch I just want a dfaster song not the chipmunks!!!:D
    Edit but it is very funny!!! Hearing st.anger chipmunk style!!
  6. couzo
    26 Apr 2002
    also is there a way to save them at the pitch you choose for quick access and portable player use?
  7. tk421
    tk421 Idiot.
    15 Jan 2002
    im not sure, i used 2 or 3 of the mkI players to beatmatch, not just change tempo ... i was looking at the problem from a dj's standpoint. <shrug>
