Storage Is it possible to reactivate sata conections after installing a M2
Discussion in 'Tech Support' started by kuroidoragon, 29 Sep 2019.
  1. kuroidoragon
    kuroidoragon Minimodder
    14 Oct 2012
    I have just installed & set up a m2 SSD but I encounterd the problem where it deactivates some sata conections after the m2 device is installed is there anyway to get all the sata connections working again after it is installed ?
  2. RedFlames
    23 Apr 2009
    No, you'll have to use different ports [if you have any available]. The motherboard manual should tell you which ports the m.2 slot shares its bandwidth with. Likewise using a NVMe SSD in the m.2 slot will often disable one or more of the on-board PCI-E slots.
    kuroidoragon likes this.
  3. sandys
    sandys Multimodder
    26 Mar 2006
    Not if there is PCIe lane sharing going on, you'll have to read the manual to see if that is the case, if you have a few M2 slots you may be able to put the drive in another slot which may have dedicated lanes.
    Alternatively, you can get a PCIe to M2 NVMe adaptor and pop it in a free PCIe slot.
    Guest-44638 and kuroidoragon like this.
  4. kuroidoragon
    14 Oct 2012
    as instructed I looked at the Mobo manual & spotted I have 2 more sata ports on the motherboard I wasn't using so I plugged in my device there so all is good now
