Electronics Is it possible to use a mobile phone wired headset on PC?
Discussion in 'Modding' started by KayinBlack, 20 Jun 2006.
  1. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    We grabbed the wrong thing at the store, but upon further inspection it's all they had, so I'm wondering if it's either compatile or moddable to work as a PC headset. I'm thinking it's possible, not sure if I want to do it, but it would be nice to know.
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    There's two issues:
    1. Mobile phone headsets usually have 2.5mm plugs, whereas sound cards and most other audio devices use 3.5mm jacks.
    2. PC mics/audio devices use 3 conductor plugs (left, right and ground for output; power, signal and ground for mics). Headsets also use 3 conductors as well: audio out, mic in and ground (the microphone being completely passive in this case).
    This is probably more effort than it's worth, because the best way to do it would involve doing a PCB, as soldering together audio cables is damn hard to impossible, thanks to each and every strand of copper being coated by something solder doesn't stick to. Plus, the end result would be a low-powered mic and only one channel of audio.
    I'd try to find a rael computer headset.
  3. KayinBlack
    2 Jul 2004
    Works for me.
    Didn't think it was worth it. I'll get it taken care of this afternoon.
  4. shotgunefx
    shotgunefx What's a Dremel?
    4 Feb 2004
  5. DougEdey
    5 Jul 2005
    The problem with that is that a PC has SEPERATE mic input and speaker output, whereas the headset will be composite (i.e. both in one)
  6. shotgunefx
    4 Feb 2004
    :duh:, didn't think that one through at all.
  7. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    I think if you have a comfortable headset ( i know i do for my cell) it would be worthit to make an adapter. split the mic and audio formthe headset, and then from the computer combine the L+R channles. Then its connect the audio to the audio, mic to the mic, and ground it all up.
    As far as i can tell, it would work.
  8. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Sorry to contradict you, but most cellphone and computer mics are not passive. They're little electret microphones. Power and signal is transfered over the same wire.
  9. thousandarm
    thousandarm What's a Dremel?
    20 Jul 2006
    HOW TO MAKE AN ADAPTER TO USE YOUR PC HEADSETS WITH ANY PHONE (CELL PHONE), WITH A ST
    This is an istruction page I am writing for some friends and another webite. I thought that it may help some people if I pasted it here. Sorry that the pictures and formating could not be included, and sorry it is so long.
    HOW TO MAKE AN ADAPTER TO USE YOUR PC HEADSETS WITH ANY PHONE (CELL PHONE), WITH A STANDARD HEADSET JACK. (In other words how to make a simple yet multi functional adapter that accepts two 3.5mm plugs and that then plugs into 2.5 in phone jacks)
    Why would you want to do this?
    There are many reasons to make this adapter. The adapter allows you to plug many devices into your phone and use the direct audio from your phone in many ways. The main reason for most people is to be able to connect your PC headset to your phone.
    How do you connect it?
    Since it is currently impossible (as far as I can tell) to find any adapter manufactured that would do the job you need to make one yourself. The adapter needs to connect the two 1/8 in plugs that are standard on PC headsets into the standard 2.5 mm jack found on most cell phones and cordless telephones handsets.
    To build it first get these parts (See picture). (They are sold at Radio shack and other hardware stores and the items numbers from radio shack.)
    1. One 1/8 Stereo Plug – Item # 274-869. That is the one with screw terminals, but you can also use the jack without screw terminals, that is just made for soldering).
    2. Two 3 conductor stereo 1/8 (3.5mm) phone jacks – Item # 274-373 (that package comes with 2). You can also use the longer covered and protected type of jacks, but they are harder to solder.
    3. One 1/8 to 3/32 adapter – Item # 274-373 (this is the 3.5 to 2.5 converter and it will have two rings on the male part.) Do not get the mono—one ring style adapter.
    4. Different colored small wires (you only need a few inches of wire). You can cut and splice wire from an extra phone chord. That works great.
    5. A PC headset. Logitech or any brand with the two 1/8 plugs on the end. One of those plugs is pink and the other one is usually colored black (but sometimes green).
    6. A cell phone or a telephone with standard headphone jack.
    The tools you need are:
    1. A wire cutter (or scissors)
    2. A soldering iron and electrical solder
    3. Electrical tape
    4. A small Phillips screwdriver (only if you got the plug with screw terminals—which I recommend.)
    Procedure
    1. Cut your wires:
    Cut each cut about 2 inches long. You will need a total of four wires. Two of the four wires need to be the same color (this will be for the ground terminals), and the other two to be of different colors (these will be for the mic and the headphone speakers).
    2. Attach wires to the 1/8 plug.
    (This is a special procedure because the cell telephone jack uses one channel to carry the sound out to the headset earphones and the other channel to carry sound in from the headset microphone. Therefore the plug is wired so that these channels can be distinguished and then in step 3 these each of these 2 separate channel wires go to its own 1/8 (3.5mm) phone jack).
    a. Unscrew and take apart the 1/8th plug. Do not loose the case and plastic liner.
    b. Connect the two wires of the same color to the longest terminal. Either screwing or soldering. I twist the wires tightly together first so there are no frayed copper filaments sticking out. The longest terminal of the 1/8 plug is the called the ground terminal. To explain the procedure I call both the wires that have the same color the ground wires, there are two of them because the ground needs to connect to both Jacks as shown in step 3).
    c. Connect the two wires you have left (they each are a different color) to the two remaining terminals which are closer to the top of the plug jack. One connects on the right terminal and the other on the left terminal. each receive one wire of a different color. (In the pictures below these are the blue and the red wires).
    d. You can solder these connections (solder if you feel the screws are not enough) or you may have to solder them if you are using a non screw type of plug.
    e. Put back the plastic liner around the connections you just made and screw the other parts of the jack back over the finished connections. Now you should have all of the wires coming out of the back of the 1/8 plug.
    3. Attach the other end of the wires to the two 1/8 jacks.
    a. Attach the ground wires to the 1/8 (3.5mm) phone jacks. These are the wires that you have two of the same color), There are two because one goes to each jack. Attach this ground near the top of each jacks. (that terminal corresponds to the connection that touches the base of the plug when the male plug is inserted into the jack.)
    b. Attach the colored wires to the 1/8 (3.5mm) phone jacks. Once wire goes to each separate jack,
    • First you need to prepare the jacks for the wires by squeezing the ends of the bottom terminals on the jacks closer together with your fingers. (You cannot squeeze together the bottom terminals if you chose to a different model jack. That is why I prefer to use the radio shack model jacks)
    • String one of the singularly colored wires through the holes on the bottom of one terminal that you just squeezed together. You need to fish it through both holes. After you fish it through, you can bend and tie it around is you are skillful. Repeat the above procedure with the other color wire and the other jack. Note: By squeezing the terminals and putting the wire through the holes you connecting the “right and left” channel of on each jack you enable the equipment to work optimally. Both ears of your headset will have the sound and the mic from your pc headset can deliver its full signal into the telephone or cell phone. (so if you are using a different style of jacks in this step you need figure out how to string the wire to connect both right and left terminals and then solder them).
    c. Solder all of your connections
    4. Test for the audio out – The moment of truth!!!!
    Now that everything is wired. You can test which jack that you made is the audio out and which is the mic in. After you figure out which is which you label these jacks so you always know which plug from the headset goes into which jack.
    a. Plug the 1/8 male plug into the One 1/8 to 3/32 adapter and plug that adapter into a standard cordless telephone or cell phone headset input jack.
    b. Plug the black (or green) 1/8 plug your headset into one of the 1/8 (3.5mm) phone jacks that you just wired. (do not use the pink plug).
    c. Put the head set on and hit talk on the phone, or if you are using the cell phone either call you voice mail or do something that produces sound.
    e. Either you will hear some of the sound/dial tone or you will not. If you hear a dial tone or your cell phone then you know that that jack you are plugged into is the audio out (for the sound that goes to your ears.)
    f. If you heard nothing in step e, then take the black (or green) headset plug out and plug it into the other 1/8 (3.5mm) phone jacks that you made. You should hear the dial tone/sound or voice mail. Whichever jack that did not produce sound in the head set is for the mic. You should label the jacks, “ear and mic” so you can remember which one correspond to the mic (pink) and which to the earphones (black-or-green). You can see in the picture that I wrap colored tape around the jacks. It would ideal if you used pink and green colors for this is becoming the standardized colors. Pink for mic and green for audio out.
    g. In this test \Did you notice how great the sound quality was? It should have been in both ears of the headset, loud and clear
    5. Finishing up
    a. Wrap the jacks in electrical tape so that the connections are not exposed.
    b. Attach the finished jacks to the plug using tape.
    c. As described above use colored tape or a pen to label your nifty adapter for ease of use.
    d. Plug into your phone and enjoy.
    Other benefits of this jack.
    Since you can connect any speaker or microphone that has a 1/8 plug into this jack, you can connect most anything to your telephone or cell phone. This enables you to do many things such as running a line into your computer terminals. Some of the things you can do are.
    • Use your PC as a telephone recording device. I’ve done this using the adapter to connect the cell or cordless telephone to the pc. I use a standard wire with 1/8 stereo plugs to connect the audio line out from the adapter to the audio line into the computer. That is in 1/8 input jack is usually colored blue on the back of the computer. Download software or use any software that records sound. Audacity is a great free ware recording program that works on PCs.
    • Turn your PC into a speaker phone that works better than most standard speaker phones. Similar to the above you connect the audio out to your PC. Then from the mic out of the adapter you can connect any pc mic that you place on your desk in front of you. (Or you can just use your headset mic that goes closer to your moth and away from your computer). Unlike most speaker phone the conversation is not cut off at all you can talk and hear the other party at the same time
    • Use the adapter to connect your phone to any mixer or PA equipment or stereo.
  10. Gjallar
    Gjallar What's a Dremel?
    1 Jan 2007
    For using a mobile headset with a PC, there's 2.5mm to PC converters available.
    thousandarm, I've been looking for something like this. That's a pretty good guide, but you should probably test the connections with a multimeter before you plug in into your phone in case there's a short or something.
  11. Emon
    Emon What's a Dremel?
    14 Jun 2004
    Nah, it's not that hard. It's only tough when they're really small, which is probably this case. The enamel coating on the wires can be soldered through, it just takes a little heat and time. Eventually it will bubble up to the top of the solder, like slag in a weld joint.
    You're right that it's not worth it for this, though.
  12. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    ive soldered audio cables before and its not that hard really, its just annoying because everything is so small.
    also to get the wires to solder properly i find that using a blowtorch or anykind of open flame to burn off the enamel then use a good flux or flux cored solder to tin or solder it works well.
  13. mghotier
    mghotier What's a Dremel?
    13 Jun 2009
    Mobile phone wired headset to PC adapter
    I think this is what you need--
    Go to ShowMeCables.com
    and search for "iPhone Heasdset adapter for Skype & Other VOIP connections F/M/M"
    I just ordered one, so haven't used it yet. But it should work.
  14. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Holy thread revival! Is this some sort of resurrection record?
  15. Macaba
    Macaba What's a Dremel?
    4 Mar 2006
    This is some kind of record revival!
    I noticed this comment:
    I highly discourage anyone from having this attitude if you are going to be a member of bit-tech! I didn't think its more effort than it's worth, and as for technical difficulty, this would be a really easy cable to solder together.
  16. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    also notice how this is his first post?!
  17. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    spam. I still cant believe this has been resurrected, I cant even remember writing that post above it was that long ago.
  18. null_x86
    null_x86 Thread Closer
    18 Jan 2009
    holy thread revival batman!!!!
  19. mirciu
    mirciu What's a Dremel?
    7 Jan 2007
    well i did it with a se k750 headset. the ground is common thick copper wire, and you have L+R for audio and a white one if memory serves well for mic. to find the specific wire color codes, you have to open the mic assembly and do some wire tracing, for mine, i was lucky some dude changed the headphones for better sound quality and he color coded the wires. old thread but fun to mess with electronics :rock:
