Planning Is it possible...
Discussion in 'Modding' started by dannyward287, 23 Mar 2010.
  1. dannyward287
    dannyward287 What's a Dremel?
    23 Mar 2010
    First off I'm not sure if this is the right thing to post this in but I came up with an idea, and needed a bit of help.
    My plan is to use an original xbox case to start it, remove everything from the innards of it, and insert a motherboard from a pc into it, but since I do not have the measurements I'm not sure it would work, once that's nailed I can get to work testing to see if it works at all.
    Afterwards if I know it works I would make my own case built to those measurements.
    Good or bad idea? anyone? :D
  2. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    Hello Danny and welcome to Bit-tech
    It is a good idea, and have actually been done before.
    Two minutes of googling brought these links:
    Old xbox
    Random xbox mods
    Xbox 360 mod
    There should be plenty of inspiration for you there to start off with.
  3. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    Can be done but will need careful planning and a rather small motherboard.
    Good luck with your mod :thumb:
  4. dannyward287
    23 Mar 2010
    ummm, thanks bigking but i didnt mean modding an xbox what i meant was using the xbox's case as a template to make my own, but since im new to all this, i was wondering if anyone could help :/.
    and how small we talking here? D:
  5. bigkingfun
    27 Jul 2008
    You will need a ITX board or smaller.
    One place to buy them is at mini-itx.com.
    I would think you would also need a 2.5" HDD and a SFF(Small Form Factor) optical drive, like the ones found in labtops.
  6. bigsharn
    bigsharn Officially demotivated
    9 May 2008
  7. jcb121
    jcb121 What's a Dremel?
    27 Dec 2009
    i have made a PC in a old xbox case.
    using a mini-itx mobo and a pico psu. use the original hard drive mount but i cut it up a bit so that the mobo can fit in. just needed a slim line disc drive and it would of been awesome. shame a threw it away to make a mame machine.
  8. dannyward287
    23 Mar 2010
    bigking, bigsharn, they are exactly what i need :) i shall start the immediate planning once i have had some sleep :D
