Education Is mouthwash worth it?
Discussion in 'General' started by Boscoe, 17 Nov 2016.
  1. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Just wondering whether it's a layer of rubbish they sell to make some money out of you? If you get the right one, can it help with whiteness and long term oral health?
  2. Big Elf
    23 Apr 2009
    I read somewhere (and I'll try and find it in the meantime) that the common ones in use kill all the nice bacteria and should only be used in rare circumstances.
    Edit: it was either this article or a very similar one.
  3. wolfticket
    19 Apr 2008
    As I recall, normal non-medicated mouth wash is just a basic antibacterial rinse. It doesn't do all that much and won't really help if you're teeth and mouth aren't already clean. That said it doesn't do any harm and does seem to help with hygiene and breath, albeit in quite a minor way. I think I heard/read a study that they all do basically the same job irrespective of price/brand/claims so I just buy cheap stuff. Sainsburys own brand is about 65p a bottle and tastes fine.
  4. freshsandwiches
    freshsandwiches Can I do science to it?
    9 Aug 2009
    You know what's best for your teeth (as well as brushing).
    Flossing.
    I hated flossing until my dentist recommended Plackers.
    http://plackers.com/
    I also use mouthwash from time to time. I buy Listerine when it's on offer.
    You can buy a huge pack of Plackers on Amazon and they'll last you ages.
  5. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    My dentist told me not to bother with mouthwash, it's something I've never really used though.
  6. Weekly_Estimate
    Weekly_Estimate Gives credit where its due
    1 Feb 2010
    Mouthwash definitely works :)
  7. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Source? You can't just come here making bold claims of things working without charts, evidence and a 56 page white paper :D
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
    I think you will find that a mouth wash is a nuke all solution rather than just killing the bad boys. I think a decent electric tooth brush is the best thing for healthy teeth and gums.
  9. theshadow2001
    3 May 2012
    You are probably better off with a tongue scraper and a full flossing once or twice a day. I also have an over priced electric toothbrush with Bluetooth. It tells me what quadrant of my mouth to brush and for how long. It was recommended to me by my hygienis. I though it was a gimmick but it's a good way to maintain a consistent brushing routine.
    In other words I don't recall ever being recommend a mouth wash except as a temporary measure (use it for a week then stop) and you are probably better of with a good brush and floss regime.
  10. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    My son was advised to use a proper mouth wash with fluoride while he had his braces and after having them removed to keep the enamel tough.
  11. Yaka
    Yaka Modder
    26 Jun 2005
    As someone who suffers from a very nasty case of gum disease. Defo use mouth wash and floss on a regular basis. I skipped my nightly routine for 6 months due long work hours and really wish i had not. Now even eating soft fruits make me gums bleed and if i take a hit to my gob i am fairly certsin most my teeth will fall out.
    Wont happen to every one but best to take caution. According to my dentist im one of the lucky ones
  12. Gareth Halfacree
    4 Dec 2007
    I was always told to use mouthwash, but at a separate time to brushing; if you don't, and you go for the advert-like brush-then-rinse-with-mouthwash routine, you're rinsing all the lovely fluoride from the toothpaste off your teeth. My dentist's recommendation was to brush, spit, but don't rinse in the morning, refrain from eating or drinking anything for half an hour after, mouthwash after lunch, brush, spit but don't rinse again just before bed.
  13. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    Fun fact - Listerine was originally marketed and sold as a household cleaner before the 1920s. Joseph Lister's work discovered that the use of carbolic acid on incisions and equipment can decrease post-surgery infections. Listerine the product was sold for use from everything to hospital antiseptic to floor cleaner. They coined or rather made up the term halitosis to sell it to the masses as mouthwash. Yes - you wash your mouth with what is basically floor cleaner. No one ever thought their breath smelled before, but Listerine told people their breath stank and they needed mouthwash. The marketing works and Listerine is the world's biggest seller of Mouthwash.
    Mouthwash doesn't actually help, your toothpaste does the job just fine. It's a placebo effect to be honest. In fact, many dentists recommend against using mouthwash as it can wash away the beneficial properties of the toothpaste you just brushed your teeth with.
    I haven't used Mouthwash since I was 16 and my gums and teeth have never suffered for not using it. Never had teeth out and I had one filling when I was 8 (too many sweets =p).
  14. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    I use a Philips Sonicare toothbrush and never use mouthwash. My dentist has never recommended I need to do anything else.
  15. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    I'd second what Mr H said, brush in the morning after breakfast don't rinse with water or MW, use mouthwash after launch if you can, and finally brush about an hour before bed and MW very last thing, MW before sleep is more important as when sleeping you produce less saliva giving the bad bacteria a chance to multiply.
    Personally i wouldn't use floss as it can drive particles into the gum line, an interdental brush dipped in MW is much better IMO but that's just my personal opinion. :)
    EDIT: Forgot to answer OP's question :), it won't help whiteness as most of the things you can buy and use at home aren't powerful enough for that, whitening is something best left to the professionals.
    Yes it helps with long term oral health, mainly because it helps remove small particles between the teeth and gums, and also because it contains fluoride that helps to reduce caries (tooth decay), there's also more specialised MW intended to help with gingivitis but unless it's specifically formulated for daily use that's something that should only be used under advise from your dentist.
  16. Almightyrastus
    Almightyrastus Rule #9
    21 Mar 2002
    I always keep a bottle of Corsodyl mouthwash in the bathroom in case of things like ulcers (which I've always been prone to) but that's about the only time that it gets used.
    Just drink more spirits, the alcohol in those will do much the same job as ordinary mouthwashes... ;)
  17. Guest-16
    Guest-16 Guest
    You want these babies with TWO strings.
    It works WAY better because it actually traps the crap you dig out between the two. I swear by them.
  18. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    That's my philosophy. Glass (or 5) of whiskey a day, keeps longevity away.
    I found that brushing too often actually made my teeth hurt, so I generally brush every 2-4 days and just rigorously rinse with water every day. I've cut most sugar heavy stuff from my diet (at least until a Saccharomyces strain is done with it) and haven't needed to visit the barbarian's office in 5 years.
  19. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Personally; Mouthwash is a lifesaver. I use it infrequently for clearing areas where I just can't get a floss (Or one of those flossing sticks) But it works a treat for it, and it's currently getting rid of the worse of the ache (And taste, ew)from my Abcess and related awful infection.
  20. Corky42
    30 Oct 2012
    They're probably in shock. J/K ;)
