PSU Is my power supply good enough? (pic included)
Discussion in 'Tech Support' started by nemmfesta, 15 Jul 2010.
  1. nemmfesta
    nemmfesta What's a Dremel?
    15 Jul 2010
    Antec 900 case, Q6600 overclocked 3.6, swiftech h2o-120 water cooling kit, sapphire's nvidia 8800gt, windows 7, DDR PC2-6400 2gb x2
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    cutting it real close if you loaded all 4 cores 100%
    q6600 loaded on all 4 pulls around 10 amps.. you have 28 on the 12 volt rail
    the 8800gt pulls around 18-19 amps fully loaded (well according to toms- it's going to be lower for regular apps and games)- it should be fine though for gaming and such
    if your running prime and furmark it might hit the wall though
  3. nemmfesta
    15 Jul 2010
    i guess thats all i needed to hear time for a new upgrade :thumb:
  4. Golygus
    Golygus Minimodder
    9 Oct 2003
    approx required wattage at peak load is 430W.
    This means you should have a PSU of 500W (75% of 500 is 375W, which should be more than your normal usage).
    *based on above spec, plus 4 HDD's. 2 Optical drives, a discreet soundcard, a 1GB 8800GT (I didn't think sapphire made cards based on nVidia chipsets?!) and overclocked Q6600 to 3.6GHz (+boost in voltage), the memory, the watercooling kit, and an additional 120mm fan.
    That sumzision PSU is a cheap nasty budget thing.
    This is what happens with budget PSU's
    Invest in a decent PSU. If you want the scope of say a second graphics card or something in the future go for a 700-800W unit. example
