Cooling Is my processor overheating?
Discussion in 'Tech Support' started by Gaming_freak_10, 12 Jul 2014.
  1. Gaming_freak_10
    Gaming_freak_10 Minimodder
    5 Jun 2010
    Hello everyone,
    I was wondering if I should be concerned that since I upgraded my Processor and reinstalled the stock fan/heatsink combo, it has been overheating..
    Here's a snapshot of my CoreTemp as of a few moments ago.
    Should I upgrade the fan/heatsink combo to make up for the upgrade?
    It's running hot for idle..
    My desktop specs
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    I would say that it is running a bit hot, especially if that's idling but I will admit I haven't used a stock cooler in absolutely ages so that may be acceptable as long as it can reign the temps in under load.
    I would consider an aftermarket heatsink if your planning on keeping it for a while. A Gelid Tranquillo can be had fairly cheaply these days and will fir the "correct" way on an AMD chip, i.e, facing front to back.
  3. Gaming_freak_10
    5 Jun 2010
    I was thinking of buying the Coolermaster Hyper 212 Evo since it's cheap and effective from what my friend told me.
  4. Deders
    Deders Modder
    14 Nov 2010
    I used to have the same CPU. Brisbane models had notoriously inaccurate temperature sensors, but still it might report that it is too hot to the bios and shut down even if it isn't actually getting that hot.
    Mine definitely reported cooler than that with a stock fan though at idle, do you have cool and quiet installed and enabled in the bios?
  5. Gaming_freak_10
    5 Jun 2010
    That's the thing, the BIOS is different.. it's Lenovo. Basically I can't do worth shite with that..
  6. manvadher
    manvadher What's a Dremel?
    28 Sep 2002
    Is the hsf hot or warm to the touch. Would rule out the faulty sensor
  7. Neogumbercules
    Neogumbercules What's a Dremel?
    14 Aug 2004
    This reminds me of my overclocked FM1 CPU that runs at 2c, and like -16c when idle. It's magic.
  8. Gaming_freak_10
    5 Jun 2010
    Ok it just unexpectedly shut down on me this morning and it barely booted up
    Sent from my 4th gen iPod touch using Tapatalk.
  9. rollo
    rollo Modder
    16 May 2008
    Could be heat related could be Lenovo related depends how much mobo access you actually get. Using the same stock Cooler did you reapply the paste or just stick it on. As if you did not apply paste that's 10-15c right there.
  10. Gaming_freak_10
    5 Jun 2010
    I applied the the paste 2 times..It's overheating on both times.. I used pea amount.. So what's going on?
    I made sure that the heatsink and fan combo (the stock ones) are on there correctly as well on both counts.
  11. Gaming_freak_10
    5 Jun 2010
    It's warm to the touch.. Hmm faulty sensor is a possibly..
  12. RedFlames
    23 Apr 2009
    The FM2 ones are a bit like that... took me a while to work out that was [as far as i can tell] the GPU temp, and that it's the GPU temp relative to the CPU temp
  13. Gaming_freak_10
    5 Jun 2010
    Ok, for some odd reason,
    After installing my new heatsink/fan combo from Coolermaster, I barely logged in my tower before shut down.. I re-did the thermal gel and everything and yet it shuts down..
    I made sure there's no shorting and all.. Is something going on with this damn thing??
    I made sure that this thing is perfectly positioned but it shuts down..
    I am so seriously pissed off at this.. I just picked this thing up today..
    It's a Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
  14. manvadher
    28 Sep 2002
    Two things from my side. Maybe a bios update or faulty psu
  15. Gaming_freak_10
    5 Jun 2010
    That's impossible. The PSU works fine before the Heatsink/fan combo upgrade..
    Hmm. I am guessing that the heatsink may not be seating correctly.. but this is my first heatsink/fan combo upgrade.. so I have no clue on how to install it properly..
    Edit: I was just told that the amount for the thermal paste that I put on the processor is too much amount. So I'll tackle this later on in the week.. Just got too much stuff on my plate.
  16. Gaming_freak_10
    5 Jun 2010
    Ok,
    I am declaring this tower dead. It's pretty much gone.. So I'm looking for another computer now..
    Will tear the tower apart to sell some of the parts off..
    UNLESS anyone has a AM2 Socket Motherboard and/or AM2 Processor available?
  17. Gaming_freak_10
    5 Jun 2010
    bump.
    Sent from my GT-P5210 using Tapatalk
