PSU Is my PSU on its way out?
Discussion in 'Tech Support' started by oasked, 12 Aug 2021.
  1. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    I've been having stability issues with my computer when playing games - but it seems to vary from game to game. Desktop performance is absolutely fine.
    Dirt Rally 2.0 can play for hours on end (I've recently left a replay running for hours on end with no issues).
    Deus Ex Mankind Divided (from 2017) and Forza Horizon 4 both seem to crash my computer. Deus Ex often completely restarts the computer. I've tried verifying the game files in Steam and the files are all ok.
    I've tried implementing an 80% power target using Asus GPU Tweak 2, but I'm still getting crashing. No artifacts on screen at all.
    For reference the system is at stock speeds for everything.
    Any thoughts? Thanks!
  2. wyx087
    15 Aug 2007
    Try a 50% power target? Need to drastically reduce it to test if it's PSU.
    What does GPU-z graph log for voltages when it crashes?
    Your sig says 3070 on a CX600. I've read reports that 3090's have huge power spikes, I'm wondering whether 3070 may produce similar high current spikes and cause the lower-tier 600w to drop in voltage.
    I had a similar low-tier Seasonic 550w PSU and when I plugged in 2080 Ti, I saw GPU-z voltage readings drop to low 11v before crashing. IIRC 50% power limit would play games fine.
    oasked likes this.
  3. oasked
    24 Aug 2005
    Well after a bit of investigation my PSU seems to be fine...
    Forza Horizon 4 sometimes plays ok and I've been trying out benchmark mode. The +12V voltage on the motherboard doesn't dip below 12.0V and is usually at around 12.2V. The 5V rail oscillates between 5.0 and 5.1V.
    Further investigation required... maybe it's the graphics card. Any signs to tell?
  4. wyx087
    15 Aug 2007
    Just a random thought, your 32GB RAM is that 4x8 or 2x16? If it's the former, it usually couldn't achieve stable XMP due to heavier load on the memory controller.
    For faulty GPU..... any hint of artifacting?
    oasked likes this.
  5. oasked
    24 Aug 2005
    It's 2x 16Gb with XMP enabled. No hints of artifacting - just straight to restart or desktop.
    I'm continuing to investigate using HW Monitor Pro to keep an eye on my system - I'm yet to catch anything significant on my monitoring but will keep at it
  6. TechBuggy
    TechBuggy What's a Dremel?
    5 Jan 2021
    You could run some stress tests to check it but nothing else really. Loop something like Heaven or Asus realbench for a couple of hours or if you really want to hammer it try OCCT's torture test but keep a close eye on your temps. I don't suppose you have a spare GPU or have a mate that could lend you theirs for testing purposes?
    oasked likes this.
  7. VictorianBloke
    VictorianBloke Man in a box
    31 Oct 2007
    That sounds identical to RAM issues I had that were eventually fixed by a newer BIOS.
    Try turning off XMP and dropping back to JDEC speeds to see if it stops the rebooting. If it does then check for BIOS updates, or try manually set the XMP frequencies rather than using auto.
    oasked likes this.
  8. oasked
    24 Aug 2005
    No spare GPU unfortunately. I will try lowering the memory speeds.
    Initial investigations with a 50% power throttle on the GPU seemed to be more stable - so could well still be the PSU. I'll report back with progress!
    Thanks all
  9. oasked
    24 Aug 2005
    After a week or so of sporadic testing at a 50% power limit on the GPU (and no other changes), I've had no crashes.
    I'll order a new (more powerful) PSU when my credit card allows in a week or so's time.
  10. sandys
    sandys Multimodder
    26 Mar 2006
    Are you running any CPU overlocks/PBO etc.
  11. oasked
    24 Aug 2005
    No. All stock, PBO is not enabled.
    Thinking of getting a Corsair RM850X (2021 version) PSU when funds allow.
  12. sandys
    sandys Multimodder
    26 Mar 2006
    Try the latest AMD chipset driver that just dropped
    oasked likes this.
  13. oasked
    24 Aug 2005
    Thanks - I have done now. Seems to have improved the stability of Forza which kept on crashing on launch.
  14. oasked
    24 Aug 2005
    I think you might be right sir!
    I've just installed a new Corsair RM850X PSU... and I still get the crashes. Just tried lowering the memory speeds to JEDEC speeds and stability has greatly improved - I can now load Forza without it crashing repeatedly. Further investigation required - but I think you might be on to something!
  15. oasked
    24 Aug 2005
    An update - I'm still continuing to pull my hair out!
    I've been fiddling around with my RAM and I just can't get the system stable with both sticks of DDR4 at stock speeds.
    I've:
    • tested each stick on its own (single channel) - no problems at full stock speeds
    • tested both sticks in dual channel - no problem at the JEDEC speeds (1066Mhz), but crashes at anything approaching stock speeds (1600Mhz) - even with looser timings. I've tried slower speeds, with looser timings which improves the situation but is not 100% stable.
    • I've updated the motherboard BIOS to the latest version (a couple of the updates mention memory compatibility improvements), but no improvement
    Any ideas?
  16. wyx087
    15 Aug 2007
  17. oasked
    24 Aug 2005
    Thanks wyx087, unfortunately those are the slots I've been using. I tried using A1 and B1 last night instead and it made the system less stable!
    I'm currently following the instructions here: https://forum.corsair.com/forums/topic/155531-cmw32gx4m2c3200c16-x570-bsod-solved/
    But it's not working for me yet. More trial and error ahead...
    UPDATE: Decided to test my memory properly with MemTest86. The results are fairly conclusive - one stick works fine at JEDEC (slow) and XMP (stock) speeds, the other stick produces errors at either. I've opened an RMA with Corsair... wish me luck.
  18. oasked
    24 Aug 2005
    Whilst I'm waiting for Corsair to respond to my RMA (still no response after several days - I am not impressed and will not be buying Corsair RAM again), I've bought some Crucial Ballistix 32GB Kit (2 x 16GB) DDR4-3600 Desktop Gaming Memory (Red) BL2K16G36C16U4R
    Seems solid so far at stock XMP speeds - no errors after an hour of MemTest86. I can also notice the improvement in performance.
    Hopefully the stability issue is now resolved. Fingers crossed.
