Is My Thermoengine Good Enough
Discussion in 'Hardware' started by bmh.01, 23 Jul 2002.
  1. bmh.01
    bmh.01 What's a Dremel?
    7 Mar 2002
    To Use On An Athlon XP 1700+/1800+ ?
    Or Is It Time To Start Saving For An Alpha ? :dude:
  2. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    It depends! What are your temps like now? Are you going to be doing any serious overclocking?
  3. bmh.01
    7 Mar 2002
    My Temps At The Moment Are 41C (Just Finished A Game Of Q3A) With A Duron 750@900.
    My Load Temp Is 45C And Idle About 37C.
    I Am Going To Add A 92mm Blowhole And Side-Intake To My Case As Well.
    Probably Will Do Some Moderate Overclocking.
  4. jamiesurfs
    21 Oct 2001
    ATM, those temps aren't too bad, but with the Athlon XP things may well change. It could be worth trying your current HSF to see how it performs. If things don't go so well or you are overly concerned, it would definitely be worth getting either an Alpha Pal8045 or a Taisol 760, especially if you want to push that baby!;)
  5. bmh.01
    7 Mar 2002
    Cheers jamiesurfs,
    I'll Try My Thermoengine First Then Get An Alpha 8045 If The Temps Are Too High For Comfort.
  6. bmh.01
    7 Mar 2002
    Just A Random Question; On A KT7A-Raid Will An Athlon XP 1800+ Be Displayed As AMD Athlon 1530Mhz Or AMD Athlon XP 1800+??
  7. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    my Aopen board posts AMD XP 1800+, when it runs at the stock speed
